Manage SnapLock audit logs
Manage SnapLock audit logs to configure, verify, and update the storage and retention of audit records within your SnapLock log volume. Use these endpoints to ensure correct log sizes and archival processes, maintaining compliance with specified retention periods.
The SnapLock log volume can be a SnapLock Compliance volume or SnapLock Enterprise volume. The SnapLock log infrastructure creates directories and files in this volume to store the SnapLock log records. The maximum log size specifies the maximum size of a log file that stores SnapLock log records. When the file reaches this size, the log infrastructure archives it and creates a new log file. The default retention period is the length of time the log file is retained, if the SnapLock log records that are stored in the file do not carry any retention period.
Verifies that the audit log is configured for the specified SVM:
GET "/api/storage/snaplock/audit-logs/?svm.name=VS0"
Verifies that the specified volume is an audit log volume:
GET "/api/storage/snaplock/audit-logs/?log_volume.volume.name=VS0_ALOG"
Creates a SnapLock log configuration by providing SVM name:
POST "/api/storage/snaplock/audit-logs" '{"svm": {"name":"VS3"}, "log_volume": { "volume": { "name":"VS3_ALOG"}, "max_log_size":"20971520", "retention_period":"P30Y" }}'
Creates a SnapLock log configuration by providing SVM UUID:
POST "/api/storage/snaplock/audit-logs" '{"svm": {"uuid":"bc744cc7-296d-11e9-a26f-0050568e5b05"}, "log_volume": { "volume": { "name":"VS3_ALOG"}, "max_log_size":"20971520", "retention_period":"P30Y" }}'
Creates a SnapLock log configuration without specifying a retention period:
POST "/api/storage/snaplock/audit-logs" '{"svm": {"name":"VS3"}, "log_volume": {"volume": {"name":"VS3_ALOG"}}}'
Updates the audit log volume:
PATCH "/api/storage/snaplock/audit-logs/bc744cc7-296d-11e9-a26f-0050568e5b05" '{"log_volume":{"volume":{"name":"VS4_ALOG_NEW"}}}'
Updates the maximum size of the log file and the retention period:
PATCH "/api/storage/snaplock/audit-logs/420cac7a-296a-11e9-a26f-0050568e5b05" '{"log_volume":{"max_log_size":"20971520", "retention_period":"P1Y"}}'
Archives all of the audit log files:
PATCH "/api/storage/snaplock/audit-logs/c7e4fa7d-2968-11e9-a26f-0050568e5b05" '{"log_archive":{"archive":"true"}}'
Archives the specified audit log file:
PATCH "/api/storage/snaplock/audit-logs/c7e4fa7d-2968-11e9-a26f-0050568e5b05" '{"log_archive":{"archive":"true","base_name":"privileged_delete"}}'
