Name-services cache netgroup settings endpoint overview
Overview
This API is used to retrieve and manage netgroups cache settings.
Retrieving a netgroup cache setting
The following example shows how to use the cache netgroup settings GET endpoint to retrieve netgroup cache settings.
# The API: GET /api/name-services/cache/netgroup/settings # The call: curl -X GET "https://<mgmt-ip>/api/name-services/cache/netgroup/settings?fields=*" -H "accept: application/hal+json" # The response: { "records": [ { "svm": { "uuid": "8a1a8730-2036-11ec-8457-005056bbcfdb", "name": "vs43" }, "enabled": true, "negative_cache_enabled_byhost": true, "ttl_byhost": "P1D", "negative_ttl_byhost": "PT30M", "ttl_for_members": "PT30M" }, { "svm": { "uuid": "dc458b2f-2035-11ec-bfe2-005056bb6bef", "name": "vs34" }, "enabled": true, "negative_cache_enabled_byhost": true, "ttl_byhost": "PT2H", "negative_ttl_byhost": "PT30M", "ttl_for_members": "PT30M" } ], "num_records": 2 }
Retrieving a netgroup cache setting for a given SVM
The following example shows how to use the cache netgroup settings GET endpoint to retrieve netgroup cache settings for a given SVM.
# The API: GET /api/name-services/cache/netgroup/settings/{svm.uuid} # The call: curl -X GET "https://<mgmt-ip>/api/name-services/cache/netgroup/settings/dc458b2f-2035-11ec-bfe2-005056bb6bef" -H "accept: application/hal+json" # The response: { "svm": { "uuid": "dc458b2f-2035-11ec-bfe2-005056bb6bef", "name": "vs34" }, "enabled": true, "negative_cache_enabled_byhost": true, "ttl_byhost": "P1D", "negative_ttl_byhost": "PT30M", "ttl_for_members": "PT30M" }
Updating a netgroup cache setting
The following example shows how to use the cache netgroup settings PATCH endpoint to update netgroup cache settings.
# The API: PATCH /api/name-services/cache/netgroup/settings/{svm.uuid} # The call: curl -X PATCH "https://<mgmt-ip>/api/name-services/cache/netgroup/settings/02c9e252-41be-11e9-81d5-00a0986138f9" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"ttl_byhost\": \"PT2H\", \"negative_ttl_byhost\": \"PT2M\" }"
