REST API reference
Update an S3 rule configuration
PATCH /protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/rules/{name}
Introduced In: 9.13
Updates the S3 bucket lifecycle rule configuration.
Important notes
  • The following fields can be modified for a bucket:
  • actions - Lifecycle Management actions associated with the rule.
  • enabled - Lifecycle Management rule is enabled or not..
  • object_age_days - Number of days since creation after which objects can be deleted.
  • object_expiry_date - Specific date from when objects can expire.
  • expired_object_delete_marker - Cleanup object delete markers.
  • new_non_current_versions - Number of latest non-current versions to be retained.
  • non_current_days - Number of days after which non-current versions can be deleted.
  • after_initiation_days - Number of days of initiation after which uploads can be aborted.
  • vserver object-store-server bucket lifecycle-management-rule modify
s3_bucket.uuid
string
path
True
The unique identifier of the bucket.
name
string
path
True
The name of the lifecycle management rule to be applied on the bucket.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
svm.uuid
string
path
True
Request Body
Name Type Description
abort_incomplete_multipart_upload
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket.
enabled
boolean
Specifies whether or not the associated rule is enabled.
expiration
expiration
Specifies a way to perform expiration action on filtered objects within a bucket.
non_current_version_expiration
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
Example request
  "expiration": {
    "object_expiry_date": "string"
Status: 200, Ok
num_records
integer
Number of records
records
array[s3_bucket_lifecycle_rule]
  "num_records": 1,
  "records": [
      "expiration": {
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error code Message
92405861
"The specified SVM UUID or bucket UUID does not exist.";
92406114
"The Expiration action requires specifying either object_expiry_date, object_age_days or expired_object_delete_marker.";
92406115
"The NonCurrentVersionExpiration action requires either new_non_current_versions or non_current_days.";
92406116
"The AbortIncompleteMultipartUpload action requires after_initiation_days.";
92406117
"The Expiration action cannot have both an expiry date and an age.";
92406118
"Using Lifecycle Management rules requires an effective cluster version of 9.13.1 .";
92406119
"One or more object store buckets exist with Lifecycle Management rules. To list the buckets, run the vserver object-store-server bucket lifecycle-management-rule show command. To delete the buckets, use the vserver object-store-server bucket delete command.";
92406120
"The AbortIncompleteMultipartUpload action cannot be specified with tags.";
92406121
"Expired object delete marker cannot be specified with tags.";
92406122
"Expired object delete marker cannot be specified with object age days or expiry date.";
92406123
"Expiration is supported on object store volumes only, bucket on Vserver is not an object store volume.";
92406126
"Lifecycle Management rule for bucket in Vserver is invalid because specified tags contain one or more invalid characters. Valid characters for a tag are 0-9, A-Z, a-z, +, -, =, ., _, :, /, @.";
92406131
"Lifecycle Management rule for bucket in Vserver cannot be created because non_current_days must be specified when new_non_current_versions is specified.";
92406132
"Lifecycle Management rule for bucket in Vserver requires object_age_days to be greater than zero.";
92406133
"Lifecycle Management rule for bucket in Vserver is invalid. The object_expiry_date must be later than January 1, 1970.";
92406135
"MetroCluster is configured on cluster. Object Expiration is not supported in a MetroCluster configuration.";
92406136
"Lifecycle Management rule for bucket in Vserver is invalid. The object_expiry_date must be at midnight GMT.";
92406139
"Lifecycle Management rule for bucket in Vserver with action is a stale entry. Contact technical support for assistance.";
92406140
"Expired object delete marker must be enabled to create a Lifecycle Management rule.";
92406141
"Lifecycle Management rule for bucket in Vserver with action cannot have expired_object_delete_marker disabled. To disable expired_object_delete_marker, run vserver object-store-server bucket lifecycle-management-rule delete";
string
integer
expiration
boolean
object_age_days
integer
object_expiry_date
string
integer
non_current_days
integer
object_filter
Specifies a way to filter objects within a bucket.
prefix
string
A prefix that is matched against object-names within a bucket.
size_greater_than
integer
Size of the object greater than specified for which the corresponding lifecycle rule is to be applied.
size_less_than
integer
Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied.
tags
array[string]
An array of key-value paired tags of the form or <tag=value>.
Information about the lifecycle management rule of a bucket.
enabled
boolean
expiration
expiration
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
