Specify list files to be added as a part of shadowcopy creation
PATCH /protocols/cifs/shadow-copies/{client_uuid}
Introduced In: 9.11
Specify list Files to be added as a part of Shadowcopy creation
Learn more
client_uuid |
string |
path |
True |
client shadowcopy ID |
restore |
boolean |
query |
False |
Indicates whether to restore a directory |
Request Body
| Name | Type | Description |
client_uuid |
string |
The universally-unique identifier of the client's shadow copy. |
destination_dir |
string |
The path of the destination directory. The path is in UTF8 and uses forward slash as a directory separator. The path is relative to the root of the volume. |
files |
array[string] |
The list of files to shadow copy in the share. The path is in UTF8 and uses forward slash as a directory separator. The path is relative to the root of the share. |
shadowcopy_set |
share |
source_dir |
string |
The path of the source directory. The path is in UTF8 and uses forward slash as a directory separator. The path is relative to the root of the volume. |
svm |
uuid |
string |
The universally-unique identifier of the storage's shadow copy. |
volume |
The name of the volume where the source and destination directories reside. |
with_content |
boolean |
Specifies what needs to be restored. False specifies the directory only. True indicates the directory and its content. |
Example request
"client_uuid": "abc13450-1f19-40ba-9b82-ebf277517e7e",
"destination_dir": "/dir2",
"files": [
"/vhd1",
"/vhd2"
"shadowcopy_set": {
"uuid": "5f4e19f3-5e2d-11ec-8766-005056a7c134"
"share": {
"name": "sh1"
"source_dir": "/dir1",
"svm": {
"name": "svm1",
"uuid": "fef32805-1f19-40ba-9b82-ebf277517e7e",
"volume": {
"name": "volume1",
Status: 200, Ok
storage_shadowcopy_set_uuid |
string |
The universally-unique identifier of the storage's shadow copy set. |
storage_shadowcopy_uuid |
string |
"storage_shadowcopy_set_uuid": "f8328660-00e6-11e6-80d9-005056bd65a9",
"storage_shadowcopy_uuid": "fef32805-1f19-40ba-9b82-ebf277517e7e"
Status: Default, Error
href |
string |
_links
self_link
shadowcopy_set
uuid |
string |
name |
string |
Share name |
svm
name |
string |
The name of the SVM. |
uuid |
string |
volume
name |
string |
The name of the volume. |
uuid |
string |
shadowcopy
client_uuid |
string |
destination_dir |
string |
files |
array[string] |
shadowcopy_set |
share |
source_dir |
string |
svm |
uuid |
string |
volume |
with_content |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
