REST API reference
Create a peering relationship
Creates a peering relationship to establish a connection between clusters, optionally specifying the IP interfaces for communication. Use this when you need to set up a new cluster peer relationship, either by providing a remote IP address or by preparing your storage system to accept requests from other clusters.
HTTP method and endpoint
POST /cluster/peers
Introduced in
ONTAP 9.6
Usage notes
Creates a peering relationship and, optionally, the IP interfaces it will use. There are two methods used to create a peering relationship:
  • Provide a remote IP address - Used when creating a new cluster peer relationship with a specific remote cluster. This requires at least one remote intercluster IP address from the remote cluster.
  • Do not provide a remote IP address - Used when the remote IP address is not provided and when the storage system is ready to accept peering requests from foreign clusters.
Required properties
  • remote.ip_addresses - Addresses of the remote peers. The local peer must be able to reach and connect to these addresses for the request to succeed in creating a peer. Only required when creating a peering relationship by providing a remote IP address.
  • Either set generate_passphrase to "true" or provide a passphrase in the body of the request. Only one of these options is required.
  • name - Name of the peering relationship or name of the remote peer.
  • passphrase - User generated passphrase for use in authentication.
  • generate_passphrase (true/false) - When "true", ONTAP automatically generates a passphrase to authenticate cluster peers.
  • ipspace - IPspace of the local intercluster LIFs. Assumes Default IPspace if not provided.
  • initial_allowed_svms - Local SVMs allowed to peer with the peer cluster's SVMs. Can be modified until the remote cluster accepts this cluster peering relationship.
  • local_network - Fields to create a local intercluster LIF.
  • expiry_time - Duration in ISO 8601 format for which the user-supplied or auto-generated passphrase is valid. Expiration time must not be greater than seven days into the future. ISO 8601 duration format is "PnDTnHnMnS" or "PnW" where n is a positive integer. The "nD", "nH", "nM" and "nS" fields can be dropped if zero. "P" must always be present and "T" must be present if there are any hours, minutes, or seconds fields.
  • encryption_proposed (none/tls-psk) - Encryption mechanism of the communication channel between the two peers.
  • peer_applications - SVM peering applications (SnapMirror, FlexCache or both) for which the SVM peering relationship is set up.
Additional information
As with creating a cluster peer through the CLI, the combinations of options must be valid in order for the create operation to succeed. The following list shows the combinations that will succeed and those that will fail:
  • A passphrase only (fail)
  • A peer IP address (fail)
  • A passphrase with an expiration time > 7 days into the future (fail)
  • A peer IP address and a passphrase (OK)
  • generate_passphrase=true (OK)
  • Any proposed encryption protocol (OK)
  • An IPspace name or UUID (OK)
  • A passphrase, peer IP address, and any proposed encryption protocol (OK)
  • A non empty list of initial allowed SVM peer names or UUIDs. (OK)
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
_links
_links
authentication
authentication
encryption
encryption
array[initial_allowed_svms]
The local SVMs allowed to peer with the peer cluster's SVMs. This list can be modified until the remote cluster accepts this cluster peering relationship.
ip_address
string
IPv4 or IPv6 address
ipspace
ipspace
The IPspace of the local intercluster LIFs.
local_network
local_network
Cluster peering requires an intercluster LIF on each local node. These can be optionally created by specifying a list of IP addresses corresponding to each node.
name
string
Optional name for the cluster peer relationship. By default, it is the name of the remote cluster, or a temporary name might be autogenerated for anonymous cluster peer offers.
peer_applications
array[string]
Peering applications against which allowed SVMs are configured.
remote
remote
status
status
uuid
string
UUID of the cluster peer relationship. For anonymous cluster peer offers, the UUID will change when the remote cluster accepts the relationship.
Example request
  "authentication": {
    "expiry_time": "P1DT2H3M4S or '2017-01-25T11:20:13Z'",
    "in_use": "string",
    "passphrase": "string",
    "state": "string"
  "encryption": {
    "proposed": "string",
    "state": "string"
  "initial_allowed_svms": [
      "name": "svm1",
  "ip_address": "10.10.10.7",
  "ipspace": {
    "name": "exchange",
  "local_network": {
    "broadcast_domain": "bd1",
    "gateway": "10.1.1.1",
    "interfaces": [
    "netmask": "255.255.0.0"
  "name": "cluster2",
  "peer_applications": [
    "snapmirror",
    "flexcache"
  "remote": {
    "ip_addresses": [
      "10.10.10.7"
    "name": "cluster2",
    "serial_number": "4048820-60-9"
  "status": {
    "state": "available",
    "update_time": "2017-01-25 11:20:13 +0000"
Status: 201, Created
num_records
integer
Number of records
records
array[cluster_peer]
  "num_records": 1,
  "records": [
      "authentication": {
        "in_use": "string",
        "state": "string"
      "encryption": {
        "state": "string"
          "name": "svm1",
      "ipspace": {
        "name": "exchange",
      "local_network": {
        "interfaces": [
      "name": "cluster2",
        "snapmirror",
        "flexcache"
      "remote": {
        "ip_addresses": [
          "10.10.10.7"
        "name": "cluster2",
      "status": {
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1966366
The system SVM of the cluster IPspace hosts cluster LIFs only.
4653365
IPspaces are unavailable with cluster peering: {ipspace}.
4656069
Specifying a passphrase without remote IP addresses is not supported.
4656070
The encryption protocol is meaningful only with authenticated cluster peer relationships.
4656071
Cannot peer with a cluster bearing the same name as the local cluster.
4656072
The name must conform to the same rules as a cluster name.
4656074
Cannot check whether all nodes of this cluster support encryption.
4656075
Cannot specify encryption: this operation requires an ECV of 9.6.0 or later.
4656077
Specify either remote IP addresses or generate_passphrase.
4656079
No cluster nodes were found. Check your cluster configuration.
4656081
Creating an intercluster LIF requires a list of local IP addresses.
4656085
Cannot create an intercluster LIF with an empty list of local IP addresses.
4656086
Creating an intercluster LIF requires a broadcast domain that is in use within the IPspace.
4656087
The number of local intercluster IP addresses must be less than or equal to the number of available nodes.
4656088
Found no ports matching the IPspace and the broadcast domain.
4656089
Found no matching entry for IPspace.
4656090
The given IPspace differs from the IPspace entry found.
4656091
Creating an intercluster LIF requires a subnet mask or a subnet mask length.
4656096
Creating an intercluster LIF requires an IPv4 or IPv6 address of the default router.
string
authentication
expiry_time
string
The time when the passphrase will expire, in ISO 8601 duration format or date and time format. The default is 1 hour.
generate_passphrase
boolean
Auto generate a passphrase when true.
in_use
string
passphrase
string
A password to authenticate the cluster peer relationship.
state
string
encryption
proposed
string
state
string
_links
_links
name
string
The name of the SVM.
uuid
string
ipspace
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
interfaces
ip_address
string
local_network
broadcast_domain
string
Broadcast domain that is in use within the IPspace.
gateway
string
The IPv4 or IPv6 address of the default router.
interfaces
array[interfaces]
netmask
string
IPv4 mask or netmask length.
remote
ip_addresses
array[string]
The IPv4 addresses, IPv6 addresses, or hostnames of the peers.
name
string
The name of the remote cluster.
serial_number
string
The serial number of the remote cluster.
status
state
string
update_time
string
The last time the state was updated.
version
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes.
full
string
The full cluster version string.
generation
integer
The generation portion of the version.
major
integer
The major portion of the version.
minor
integer
The minor portion of the version.
cluster_peer
_links
_links
authentication
authentication
encryption
encryption
ip_address
string
ipspace
ipspace
local_network
local_network
name
string
peer_applications
array[string]
remote
remote
status
status
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
