Create a cluster
Creates a cluster, initiating a new ONTAP storage environment. Use this endpoint when you need to establish a fresh cluster setup with specific configurations.
HTTP method and endpoint
POST /cluster
Introduced in
ONTAP 9.6
Required properties
name -
password
Recommended optional properties
location -
contact -
dns_domains -
name_servers -
ntp_servers -
license -
configuration_backup -
management_interface -
nodes -
timezone
Learn more
single_node_cluster |
boolean |
query |
False |
Configures a single node cluster. All cluster ports are reassigned to the default network. The storage failover settings are configured to non-HA. The node reboots during this operation. |
create_recommended_aggregates |
boolean |
query |
False |
Create aggregates based on an optimal layout recommended by the system.
keep_precluster_config |
boolean |
query |
False |
This is used to keep temporary configuration settings that allow initial setup including a node scoped certificate and possibly an automatically created node management interface. This is useful when creating a GUI that does not replace the node management interface using POST on /api/cluster, but instead creates the interface at another time. The certificate also relates to creating a web based GUI so that the certificate lasts through the entire workflow and is not replaced by the cluster scoped certificate during POST on /api/cluster. To remove the temporary configuration settings when a custom setup workflow is complete, set the remove_precluster_config query parameter in a PATCH on /api/cluster.
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
_links |
_tags |
array[string] |
Tags are an optional way to track the uses of a resource. Tag values must be formatted as key:value strings. |
auto_enable_activity_tracking |
boolean |
Indicates how new SVMs will default "auto_enable_activity_tracking" for new volumes. |
auto_enable_analytics |
boolean |
Indicates how new SVMs will default "auto_enable_analytics" for new volumes. |
configuration_backup |
contact |
string |
dns_domains |
array[string] |
A list of DNS domains. Domain names have the following requirements:
license |
License keys or NLF contents. |
location |
string |
management_interface |
The management interface of the cluster. The subnet mask and gateway for this interface are used for the node management interfaces provided in the node configuration. |
management_interfaces |
array[management_interfaces] |
name |
string |
name_servers |
array[string] |
The list of IP addresses of the DNS servers. Addresses can be either IPv4 or IPv6 addresses. |
nodes |
array[nodes] |
ntp_servers |
array[string] |
Host name, IPv4 address, or IPv6 address for the external NTP time servers. |
password |
string |
Initial admin password used to create the cluster. |
peering_policy |
san_optimized |
boolean |
Specifies if this cluster is an All SAN Array. |
timezone |
Provides the cluster-wide time zone information that localizes time found on messages displayed on each node's:
uuid |
string |
Example request
"_tags": [
"team:csi",
"environment:test"
"configuration_backup": {
"password": "yourpassword",
"url": "http://10.224.65.198/backups",
"username": "me"
"contact": "support@company.com",
"dns_domains": [
"example.com",
"example2.example3.com"
"license": {
"keys": [
"AMEPOSOIKLKGEEEEDGNDEKSJDE"
"location": "building 1",
"management_interface": {
"ip": {
"address": "10.10.10.7",
"gateway": "10.1.1.1",
"netmask": "24"
"management_interfaces": [
"name": "lif1",
"name": "cluster1",
"name_servers": [
"10.224.65.20",
"2001:db08:a0b:12f0::1"
"nodes": [
"cluster_interface": {
"ip": {
"cluster_interfaces": [
"name": "lif1",
"controller": {
"board": "System Board XXVIII",
"cpu": {
"count": 20,
"firmware_release": "string",
"processor": "string"
"failed_fan": {
"count": 1,
"message": {
"code": "111411207",
"message": "There are no failed fans."
"failed_power_supply": {
"count": 1,
"message": {
"code": "111411208",
"message": "There are no failed power supplies."
"flash_cache": [
"capacity": 1024000000000,
"device_id": 0,
"firmware_file": "X9170_O000Z6300NVM",
"firmware_version": "NA05",
"hardware_revision": "A1",
"model": "X1970A",
"part_number": "119-00207",
"serial_number": "A22P5061550000187",
"slot": "6-1",
"state": "string"
"frus": [
"id": "string",
"state": "string",
"type": "string"
"memory_size": 1024000000,
"over_temperature": "string"
"date": "2019-04-17 15:49:26 +0000",
"ha": {
"giveback": {
"failure": {
"code": 852126,
"message": "Failed to initiate giveback. Run the \"storage failover show-giveback\" command for more information."
"state": "failed",
"status": [
"aggregate": {
"name": "aggr1",
"error": {
"code": "852126",
"message": "string"
"state": "string"
"interconnect": {
"adapter": "MVIA-RDMA",
"state": "string"
"partners": [
"name": "node1",
"ports": [
"number": 0,
"state": "active"
"takeover": {
"failure": {
"code": 852130,
"message": "Failed to initiate takeover. Run the \"storage failover show-takeover\" command for more information."
"state": "failed"
"location": "rack 2 row 5",
"ip": {
"name": "lif1",
"membership": "string",
"metrocluster": {
"ports": [
"name": "e1b"
"type": "string"
"model": "FAS3070",
"name": "node-01",
"nvram": {
"battery_state": "string",
"id": 0
"owner": "Example Corp",
"serial_number": "4048820-60-9",
"service_processor": {
"api_service": {
"port": 0
"auto_config": {
"ipv4_subnet": "ipv4_mgmt",
"ipv6_subnet": "ipv6_mgmt"
"autoupdate_enabled": true,
"backup": {
"state": "string",
"version": "11.6"
"dhcp_enabled": true,
"firmware_version": "string",
"ipv4_interface": {
"netmask": "24"
"last_update_state": "string",
"link_status": "string",
"mac_address": "string",
"primary": {
"state": "string",
"version": "11.6"
"ssh_info": {
"allowed_addresses": [
"10.10.10.7/24"
"state": "string",
"type": "string"
"state": "string",
"storage_configuration": "string",
"system_id": 92027651,
"system_machine_type": "7Y56-CTOWW1",
"uptime": 300536,
"uuid": "4ea7a442-86d1-11e0-ae1c-123478563412",
"vendor_serial_number": 791603000068,
"vm": {
"provider_type": "string"
"ntp_servers": [
"time.nist.gov",
"10.98.19.20",
"2610:20:6F15:15::27"
"password": "mypassword",
"peering_policy": {
"minimum_passphrase_length": 0
"timezone": {
"name": "America/New_York"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262245 |
The value provided is invalid. |
1179813 |
Fields set for one node must be set for all nodes. |
1179817 |
The IP address, subnet mask, and gateway must all be provided for cluster manangement interface. |
1179818 |
The IP address and gateway must be of the same family. |
1179821 |
An IP address and subnet mask conflicts with an existing entry. |
1179824 |
An invalid gateway was provided. |
1179825 |
All management and cluster config IP addresses must belong to the same address family. |
2097165 |
An NTP server could not be reached. |
8847361 |
Too many DNS domains provided. |
8847362 |
Too many name servers provided. |
8847394 |
An invalid DNS domain was provided. |
8978433 |
An invalid license key was provided. |
9240587 |
A name must be provided. |
9240594 |
An invalid name was provided. |
39387137 |
The URL provided is invalid. |
131727360 |
A node could not be added to the cluster. This is a generic code, see response message for details. |
131727388 |
Hostnames for NTP servers cannot be used without DNS configured. |
131727389 |
URL and username are required for configuration backup. |
href |
string |
_links
certificate
Support for this field will be removed in a future release. Please use /api/cluster/web for this field. Certificate used by cluster and node management interfaces for TLS connection requests.
_links |
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
password |
string |
url |
string |
An external backup location for the cluster configuration. This is mostly required for single node clusters where node and cluster configuration backups cannot be copied to other nodes in the cluster. |
username |
string |
validate_certificate |
boolean |
Use this parameter with the value "true" to validate the digital certificate of the remote server. Digital certificate validation is available only when the HTTPS protocol is used in the URL; it is disabled by default. |
license
keys |
array[string] |
ip
Object to setup an interface along with its default router.
address |
string |
IPv4 or IPv6 address |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
ip |
Object to setup an interface along with its default router. |
ip
IP information
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
other |
integer |
read |
integer |
total |
integer |
write |
integer |
metric
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
node_setup_ip
The IP configuration for cluster setup.
address |
string |
cluster_interface
The cluster network IP address of the node to be added.
ip |
The IP configuration for cluster setup. |
cluster_interfaces
Network interface
ip |
IP information |
name |
string |
uuid |
string |
cpu
CPU information.
count |
integer |
Number of CPUs on the node. |
firmware_release |
string |
Firmware release number. Defined by the CPU manufacturer. |
processor |
string |
CPU type on the node. |
message
code |
string |
Error code describing the current condition of chassis fans. |
message |
string |
Message describing the current condition of chassis fans. It is only of use when |
failed_fan
count |
integer |
Specifies a count of the number of chassis fans that are not operating within the recommended RPM range. |
message |
message
code |
string |
Error code describing the current condition of power supply. |
message |
string |
Message describing the state of any power supplies that are currently degraded. It is only of use when |
failed_power_supply
count |
integer |
Number of failed power supply units. |
message |
flash_cache
capacity |
integer |
Size in bytes |
device_id |
integer |
firmware_file |
string |
firmware_version |
string |
hardware_revision |
string |
model |
string |
part_number |
string |
serial_number |
string |
slot |
string |
state |
string |
frus
id |
string |
state |
string |
type |
string |
controller
Controller information
board |
string |
Type of the system board. This is defined by vendor. |
cpu |
CPU information. |
failed_fan |
failed_power_supply |
flash_cache |
array[flash_cache] |
A list of Flash-Cache devices. Only returned when requested by name. |
frus |
array[frus] |
List of FRUs on the node. Only returned when requested by name. |
memory_size |
integer |
Memory available on the node, in bytes. |
over_temperature |
string |
Specifies whether the hardware is currently operating outside of its recommended temperature range. The hardware shuts down if the temperature exceeds critical thresholds. |
external_cache
Cache used for buffer management.
failure
Indicates the failure code and message.
code |
integer |
Message code |
message |
string |
Detailed message based on the state. |
aggregate
Aggregate name and UUID.
name |
string |
uuid |
string |
error
Indicates the failed aggregate giveback code and message.
code |
string |
Message code. |
message |
string |
status
aggregate |
Aggregate name and UUID. |
error |
Indicates the failed aggregate giveback code and message. |
state |
string |
Giveback state of the aggregate. Possible values include no aggregates to giveback(nothing_to_giveback), failed to disable background disk firmware update(BDFU) on source node(failed_bdfu_source), giveback delayed as disk firmware update is in progress on source node(delayed_bdfu_source), performing veto checks(running_checks). |
giveback
Represents the state of the node that is giving storage back to its HA partner.
failure |
Indicates the failure code and message. |
state |
string |
status |
array[status] |
Giveback status of each aggregate. |
interconnect
adapter |
string |
HA interconnect device name. |
state |
string |
Indicates the HA interconnect status. |
partners
name |
string |
uuid |
string |
ports
number |
integer |
HA port number |
state |
string |
HA port state:
takeover
This represents the state of the node that is taking over storage from its HA partner.
failure |
state |
string |
ha
auto_giveback |
boolean |
Specifies whether giveback is automatically initiated when the node that owns the storage is ready. |
enabled |
boolean |
Specifies whether or not storage failover is enabled. |
giveback |
Represents the state of the node that is giving storage back to its HA partner. |
interconnect |
partners |
array[partners] |
Nodes in this node's High Availability (HA) group. |
ports |
array[ports] |
takeover |
This represents the state of the node that is taking over storage from its HA partner. |
local
ip |
string |
The hardware assist IP address. |
port |
integer |
The hardware assist port. |
state |
string |
The hardware assist monitor status. |
partner
ip |
string |
port |
integer |
state |
string |
status
enabled |
boolean |
Indicates whether hardware assist is enabled on the node. |
hw_assist
The hardware assist information.
The management interface of the node to be added. The subnet mask is set based on the management interface of the cluster or the management interfaces of other nodes.
ip |
Network interface
ip |
IP information |
name |
string |
uuid |
string |
metric
CPU performance for the nodes.
duration |
string |
processor_utilization |
integer |
Average CPU Utilization for the node |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
timestamp |
string |
uuid |
string |
ports
name |
string |
metrocluster
Metrocluster
custom_vlan_capable |
boolean |
Indicates whether the MetroCluster over IP platform supports custom VLAN IDs. |
ports |
array[ports] |
MetroCluster over IP ports. |
type |
string |
The Metrocluster configuration type |
nvram
battery_state |
string |
Specifies status of the NVRAM battery. Possible values:
id |
integer |
Vendor specific NVRAM ID of the node. |
api_service
Provides the properties of the service processor API service.
enabled |
boolean |
Indicates whether the service processor API service is enabled. |
limit_access |
boolean |
Indicates whether the service processor API service limit access is enabled. |
port |
integer |
Indicates the port number of service processor API service. |
auto_config
Provides the properties of the service processor auto configuration.
ipv4_subnet |
string |
Indicates the service processor auto configuration IPv4 subnet name. To enable IPv4 auto-config give the subnet name, give the value as null or an empty string "" to disable auto-config. |
ipv6_subnet |
string |
Indicates the service processor auto configuration IPv6 subnet name. To enable IPv6 auto-config give the subnet name, give the value as null or an empty string "" to disable auto-config. |
backup
Provides the properties of the service processor backup partition.
is_current |
boolean |
Indicates whether the service processor is currently booted from the backup partition. |
state |
string |
Status of the backup partition. |
version |
string |
Firmware version of the backup partition. |
ipv4_interface
address |
string |
gateway |
string |
netmask |
string |
ipv6_interface
address |
string |
IPv6 address |
gateway |
string |
The IPv6 address of the default router. |
netmask |
integer |
The IPv6 netmask/prefix length. The default value is 64 with a valid range of 1 to 127. |
primary
Provides the properties of the service processor primary partition.
is_current |
boolean |
Indicates whether the service processor is currently booted from the primary partition. |
state |
string |
Status of the primary partition. |
version |
string |
Firmware version of the primary partition. |
ssh_info
Service processor SSH allowed IP address configuration applied across the cluster.
allowed_addresses |
array[string] |
Allowed IP addresses |
service_processor
api_service |
Provides the properties of the service processor API service. |
auto_config |
Provides the properties of the service processor auto configuration. |
backup |
Provides the properties of the service processor backup partition. |
firmware_version |
string |
The version of firmware installed. |
ipv4_interface |
is_ip_configured |
boolean |
Indicates whether the service processor network is configured. |
last_update_state |
string |
Provides the "update status" of the last service processor update. |
link_status |
string |
mac_address |
string |
primary |
Provides the properties of the service processor primary partition. |
ssh_info |
Service processor SSH allowed IP address configuration applied across the cluster. |
state |
string |
type |
string |
snaplock
SnapLock-related properties.
compliance_clock_time |
string |
SnapLock compliance clock time. |
statistics
Raw CPU performance for the nodes.
processor_utilization_base |
integer |
Base counter for CPU Utilization. |
processor_utilization_raw |
integer |
Raw CPU Utilization for the node. This should be divided by the processor_utilization_base to calculate the percentage CPU utilization for the node. |
status |
string |
timestamp |
string |
version
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes.
full |
string |
The full cluster version string. |
generation |
integer |
The generation portion of the version. |
major |
integer |
The major portion of the version. |
minor |
integer |
The minor portion of the version. |
vm
provider_type |
string |
Cloud provider where the VM is hosted. |
nodes
Complete node information
_links |
cluster_interface |
The cluster network IP address of the node to be added. |
cluster_interfaces |
array[cluster_interfaces] |
controller |
Controller information |
date |
string |
The current or "wall clock" time of the node in ISO-8601 date, time, and time zone format. The ISO-8601 date and time are localized based on the ONTAP cluster's timezone setting.
ha |
is_spares_low |
boolean |
Specifies whether or not the node is in spares low condition. |
location |
string |
The management interface of the node to be added. The subnet mask is set based on the management interface of the cluster or the management interfaces of other nodes. |
membership |
string |
Possible values:
metrocluster |
Metrocluster |
model |
string |
name |
string |
nvram |
owner |
string |
Owner of the node. |
serial_number |
string |
service_processor |
state |
string |
State of the node:
storage_configuration |
string |
The storage configuration in the system. Possible values:
system_id |
string |
system_machine_type |
string |
OEM system machine type. |
uptime |
integer |
The total time, in seconds, that the node has been up. |
uuid |
string |
vendor_serial_number |
string |
OEM vendor serial number. |
vm |
peering_policy
authentication_required |
boolean |
Indicates whether authentication is required in the communication between cluster peers. If true, authentication is required to establish communication between cluster peers. |
encryption_required |
boolean |
Indicates whether encryption is required in the communication between cluster peers. If true, encryption is required to establish communication between cluster peers. |
minimum_passphrase_length |
integer |
Minimum required length for a passphrase. For more information on password strength best practices, see: https://cheatsheetseries.owasp.org/cheatsheets/Authentication_Cheat_Sheet.html#implement-proper-password-strength-controls |
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
statistics
iops_raw |
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
throughput_raw |
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
timezone
console messages;
logging to internal ONTAP log files; and
localized REST API full ISO-8601 date, time, and time zone format information. Machine-to-machine interfaces, such as file access protocols (NFS, CIFS), block access protocols (SAN), and other protocols such as Manage ONTAP (ONTAPI), use second or subsecond time values that are based on world time or UTC.
name |
string |
The ONTAP time zone name or identification in either IANA time zone format "Area/Location", or an ONTAP traditional time zone. The initial first node in cluster setting for time zone is "Etc/UTC". "Etc/UTC" is the IANA timezone "Area/Location" specifier for Coordinated Universal Time (UTC), which is an offset of 0. IANA time zone formatThe IANA time zone, formatted as "Area/Location", is based on geographic areas that have had the same time zone offset for many years. "Location" represents a compound name using additional forward slashes. An example of the "Area/Location" time zone is "America/New_York" and represents most of the United States Eastern Time Zone. Examples of "Area/Location" with "Location" as a compound name are "America/Argentina/Buenos_Aires" and "America/Indiana/Indianapolis". ONTAP traditional time zoneExamples of the traditional time zones are "EST5EDT" for the United States Eastern Time Zone and "CET" for Central European Time Zone.
cluster
Complete cluster information
_links |
_tags |
array[string] |
boolean |
boolean |
contact |
string |
dns_domains |
array[string] |
license |
location |
string |
name |
string |
name_servers |
array[string] |
nodes |
array[nodes] |
ntp_servers |
array[string] |
password |
string |
peering_policy |
san_optimized |
boolean |
timezone |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
