REST API reference
Creates the s3 bucket lifecycle rule configuration
  • actions - lifecycle management actions associated with the rule # recommended optional properties
  • enabled - lifecycle management rule is enabled or not
  • object_filterprefix - lifecycle management rule filter prefix
  • object_filtertags - lifecycle management rule filter tags
  • object_filtersize_greater_than - lifecycle management rule filter minimum object size
  • object_filtersize_less_than - lifecycle management rule filter maximum object size
  • object_age_days - number of days since creation after which objects can be deleted
  • object_expiry_date - specific date from when objects can expire
  • expired_object_delete_marker - cleanup object delete markers
  • new_non_current_versions - number of latest non-current versions to be retained
  • non_current_days - number of days after which non-current versions can be deleted
  • after_initiation_days - number of days of initiation after which uploads can be aborted # related ontap commands
  • vserver object-store-server bucket lifecycle-management-rule create # learn more
  • [doc /protocols/s3/services/{svmuuid}/buckets/{s3_bucketuuid}/rules](#docs-object-store-protocols_s3_services_{svmuuid}_buckets_{s3_bucketuuid}_rules)
POST /protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/rules
Introduced In: 9.13
Creates the S3 bucket lifecycle rule configuration.
Required properties
  • name - Lifecycle Management rule to be created.
  • actions - Lifecycle Management actions associated with the rule.
  • enabled - Lifecycle Management rule is enabled or not.
  • object_filter.prefix - Lifecycle Management rule filter prefix.
  • object_filter.tags - Lifecycle Management rule filter tags.
  • object_filter.size_greater_than - Lifecycle Management rule filter minimum object size.
  • object_filter.size_less_than - Lifecycle Management rule filter maximum object size.
  • object_age_days - Number of days since creation after which objects can be deleted.
  • object_expiry_date - Specific date from when objects can expire.
  • expired_object_delete_marker - Cleanup object delete markers.
  • new_non_current_versions - Number of latest non-current versions to be retained.
  • non_current_days - Number of days after which non-current versions can be deleted.
  • after_initiation_days - Number of days of initiation after which uploads can be aborted.
s3_bucket.uuid
string
path
True
Unique identifier of a bucket.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
abort_incomplete_multipart_upload
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket.
enabled
boolean
Specifies whether or not the associated rule is enabled.
expiration
expiration
Specifies a way to perform expiration action on filtered objects within a bucket.
name
string
Bucket lifecycle management rule identifier.
non_current_version_expiration
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
object_filter
object_filter
Specifies a way to filter objects within a bucket.
Example request
  "expiration": {
    "object_expiry_date": "string"
  "name": "string",
  "object_filter": {
    "prefix": "/logs",
    "size_greater_than": 10485760,
    "size_less_than": 10240,
    "tags": [
      "project1=projA",
      "project2=projB"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error code Message
92405861
"The specified SVM UUID or bucket UUID does not exist.";
92406111
"Lifecycle Management rule for bucket in Vserver is invalid because of the number of tags specified. The maximum number of tags supported is four.";
92406113
"Lifecycle Management rule for bucket in Vserver is invalid because there is a mismatch in one of the filter-field. Filters must be the same for a particular rule identifier.";
92406114
"The Expiration action requires specifying either object_expiry_date, object_age_days or expired_object_delete_marker.";
92406115
"The NonCurrentVersionExpiration action requires either new_non_current_versions or non_current_days.";
92406116
"The AbortIncompleteMultipartUpload action requires after_initiation_days.";
92406117
"The Expiration action cannot have both an expiry date and an age.";
92406118
"Using Lifecycle Management rules requires an effective cluster version of 9.13.1 .";
92406119
"One or more object store buckets exist with Lifecycle Management rules. To list the buckets, run the vserver object-store-server bucket lifecycle-management-rule show command. To delete the buckets, use the vserver object-store-server bucket delete command.";
92406120
"The AbortIncompleteMultipartUpload action cannot be specified with tags.";
92406121
"Expired object delete marker cannot be specified with tags.";
92406122
"Expired object delete marker cannot be specified with object age days or expiry date.";
92406123
"Expiration is supported on object store volumes only, bucket on Vserver is not an object store volume.";
92406126
"Lifecycle Management rule for bucket in Vserver is invalid because specified tags contain one or more invalid characters. Valid characters for a tag are 0-9, A-Z, a-z, +, -, =, ., _, :, /, @.";
92406127
"Lifecycle Management rule for bucket in Vserver is invalid because specified tag length is greater than maximum allowed length: {1}.";
92406128
"Lifecycle Management rule for bucket in Vserver has tags with duplicate keys. Ensure each tag has a unique key and try the operation again.";
92406129
"Lifecycle Management rule for bucket in Vserver has a prefix that is too long. The maximum length of the prefix is 1024 characters.";
92406130
"Lifecycle Management rule for bucket in Vserver is invalid because the minimum object size is larger than the maximum object size.";
92406131
"Lifecycle Management rule for bucket in Vserver cannot be created because non_current_days must be specified when new_non_current_versions is specified.";
92406132
"Lifecycle Management rule for bucket in Vserver requires object_age_days to be greater than zero.";
92406133
"Lifecycle Management rule for bucket in Vserver is invalid. The object_expiry_date must be later than January 1, 1970.";
92406134
"Cannot exceed the max limit of 1000 Lifecycle Management rules per bucket.";
92406135
"MetroCluster is configured on cluster. Object Expiration is not supported in a MetroCluster configuration.";
92406136
"Lifecycle Management rule for bucket in Vserver is invalid. The object_expiry_date must be at midnight GMT.";
92406139
"Lifecycle Management rule for bucket in Vserver with action is a stale entry. Contact technical support for assistance.";
92406140
"Expired object delete marker must be enabled to create a Lifecycle Management rule.";
92406141
"Lifecycle Management rule for bucket in Vserver with action cannot have expired_object_delete_marker disabled. To disable expired_object_delete_marker, run vserver object-store-server bucket lifecycle-management-rule delete";
92406142
"Cannot create fabriclink relationship between bucket A and bucket B. Reason : {2}.";
92406143
"The AbortIncompleteMultipartUpload action cannot be specified with object size.";
string
integer
expiration
boolean
object_age_days
integer
object_expiry_date
string
integer
non_current_days
integer
object_filter
prefix
string
A prefix that is matched against object-names within a bucket.
size_greater_than
integer
Size of the object greater than specified for which the corresponding lifecycle rule is to be applied.
size_less_than
integer
Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied.
tags
array[string]
An array of key-value paired tags of the form or <tag=value>.
s3_bucket_lifecycle_rule
Information about the lifecycle management rule of a bucket.
enabled
boolean
expiration
expiration
name
string
object_filter
object_filter
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
