REST API reference
Update the user account password
Updates the password for a user account, ensuring the account remains secure with a new authentication credential. This is useful when you need to change passwords for maintenance or security purposes.
HTTP method and endpoint
POST /security/authentication/password
Introduced in
ONTAP 9.6
Required parameters
  • name - User account name.
  • password - New password for the user account.
Optional parameters
  • owner.name or owner.uuid - Name or UUID of the SVM for an SVM-scoped user account.
  • password_hash_algorithm - Optional property that specifies the password hash algorithm used to generate a hash of the user's password for password matching. Default value is "sha512".
  • security login password
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
name
string
The user account name whose password is being modified.
owner
owner
Owner name and UUID that uniquely identifies the user account. This field is optional and valid only when a cluster administrator is executing the API to uniquely identify the account whose password is being modified. The "owner" field is not required to be specified for SVM user accounts trying to modify their password.
password
string
The password string
string
Example request
  "name": "string",
  "owner": {
    "name": "svm1",
  "password": "string",
  "password_hash_algorithm": "sha512"
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
7077918
The password cannot contain the username.
7077919
The minimum length for new password does not meet the policy.
7077920
The new password must have both letters and numbers.
7077921
The minimum number of special characters required do not meet the policy.
7077924
The new password must be different than last N passwords.
7077925
The new password must be different to the old password.
7077940
The password exceeds maximum supported length.
7077941
Defined password composition exceeds the maximum password length of 128 characters.
string
owner
_links
_links
name
string
The name of the SVM.
uuid
string
account_password
The password object
name
string
owner
owner
password
string
The password string
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
