REST API reference
Protocols CIFS users-and-groups privileges endpoint overview
Overview
Privileges associated with local or Active Directory users or groups defines the permissions for the specified user or group. You can use this API to display and/or control privileges of local or Active Directory users or groups.
Retrieving the privileges of a specific local or Active Directory user or group and an SVM
The users and groups privileges GET endpoint retrieves privileges of the specified local or Active Directory user or group and the SVM.
Retrieving the privileges of all of the users or groups of data SVMs.
# The API:
/api/protocols/cifs/users-and-groups/privileges
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/users-and-groups/privileges?fields=*" -H "accept: application/json"
# The response:
"records": [
    "svm": {
      "uuid": "25b363a6-2971-11eb-88e1-0050568eefd4",
      "name": "vs1"
    "name": "VS1.CIFS\\user1",
    "privileges": [
      "SeChangeNotifyPrivilege",
      "SeTakeOwnershipPrivilege"
    "svm": {
      "name": "vs1"
    "name": "ACTIVE_DIRECTORY\\user",
    "privileges": [
      "SeBackupPrivilege",
    "svm": {
      "uuid": "0ac79c37-3867-11eb-bece-0050568ed0a2",
      "name": "vs2"
    "name": "VS2.CIFS\\group1",
    "privileges": [
      "SeSecurityPrivilege",
      "SeRestorePrivilege"
Retrieving the privileges of the specific SVM and user or group
# The API:
/api/protocols/cifs/users-and-groups/{svm.uuid}/{name}/privileges
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/users-and-groups/privileges/25b363a6-2971-11eb-88e1-0050568eefd4/user1" -H "accept: application/json"
# The response:
"svm": {
  "name": "vs1"
"privileges": [
Adding privileges to the local or Active Directory user or group
The users and groups privileges POST endpoint adds privileges to the specified local or Active Directory user or group and the SVM.
Adding the privileges to the local user 'user1'
# The API:
/api/protocols/cifs/users-and-groups/privileges/{svm.uuid}/{name}
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/cifs/users-and-groups/privileges/179d3c85-7053-11e8-b9b8-005056b41bd1/user1" -H "accept: application/json" -H "Content-Type: application/json" -d '{ "privileges": [ "SeSecurityPrivilege", "SeBackupPrivilege", "SeRestorePrivilege"] }'
Updating the privileges of the local or Active Directory user or group of a specific SVM
Example
Updating the privileges of local user 'user1' in SVM 'vs1' to 'SeRestorePrivilege' and 'SeSecurityPrivilege'
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/cifs/users-and-groups/privileges/179d3c85-7053-11e8-b9b8-005056b41bd1/user1" -H "accept: application/json" -d '{ "privileges": [ "SeRestorePrivilege", "SeSecurityPrivilege"] }'
Reset all the privileges associated with the local user 'user1' in SVM 'vs1'
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/cifs/users-and-groups/privileges/179d3c85-7053-11e8-b9b8-005056b41bd1/user1" -H "accept: application/json" -d '{ "privileges": [ ] }'
