REST API reference
Protocols NDMP nodes endpoint overview
You can use this API to manage node configurations. The authentication types "plaintext" and "plaintext_sso" are used to show that the password uses clear text. Also, they contain no differences for NDMP node scope.
Updates "enabled" and "authentication_types" fields:
 PATCH "/api/protocols/ndmp/nodes/13bb2092-458b-11e9-9c06-0050568ea64e" '{"enabled":"false","authentication_types":["plaintext"]}'
Updates the "user" field:
 PATCH "/api/protocols/ndmp/nodes/13bb2092-458b-11e9-9c06-0050568ea64e" '{"user":"user22"}'
