Retrieve cluster chassis
Retrieve detailed information about all chassis within your cluster using these endpoints. Access chassis data to monitor hardware components and their status efficiently.
Overview
You can use the chassis GET API to retrieve all of the chassis information in the cluster.
Retrieving a list of chassis from the cluster
The following example shows the response with a list of chassis in the cluster:
# The API:
/api/cluster/chassis
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/chassis" -H "accept: application/hal+json"
# The response:
"records": [
"id": "021352005981",
"href": "/api/cluster/chassis/021352005981"
"num_records": 1,
"href": "/api/cluster/chassis"
Retrieving a specific chassis from the cluster
The following example shows the response of the requested chassis. If there is no chassis with the requested ID, an error is returned.
# The API:
/api/cluster/chassis/{id}
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/chassis/021352005981" -H "accept: application/hal+json"
# The response:
"state": "ok",
"nodes": [
"name": "node-1",
"uuid": "6ede364b-c3d0-11e8-a86a-00a098567f31",
"position": "top",
"usbs": {
"supported": true,
"enabled": true,
"ports": [
"connected": false
"pcis": {
"cards": [
"slot": "0",
"device": "Gigabit Ethernet I210",
"info": "\t e0M MAC Address: d0:39:ea:3f:06:2b (auto-1000t-fd-up) \n\t e0S MAC Address: d0:39:ea:3f:06:2c (auto-1000t-fd-up) \n\t Device Type: 1533\n\t Firmware Version: 3.25-0.0 0x800005D1\n"
"slot": "0",
"device": "Intel Lewisburg series chipset SATA Controller",
"info": "\t Additional Info: 0 (0xaaf00000) \n\t SHM2S86Q120GLM22NP FW1146 114473MB 512B/sect (SPG190108HJ) \n"
"href": "/api/cluster/nodes/6ede364b-c3d0-11e8-a86a-00a098567f31"
"frus": [
"id": "PSU2",
"type": "psu",
"state": "ok"
"id": "PSU1",
"type": "psu",
"state": "ok"
"id": "Fan2",
"type": "fan",
"state": "ok"
"id": "Fan3",
"type": "fan",
"state": "ok"
"id": "Fan1",
"type": "fan",
"state": "ok"
