Retrieve MetroCluster operations
Retrieve a list of recent MetroCluster operations using these endpoints to monitor and assess the status of your cluster activities. For detailed information on individual operations, refer to the specific operation endpoint.
Overview
Retrieves a list of recent MetroCluster operations. To view more information about a specific operation, use the /cluster/metrocluster/operations/{uuid} API endpoint.
Retrieves all MetroCluster operations
GET https://<mgmt-ip>/api/cluster/metrocluster/operations?fields=*
"records": [
"uuid": "a14ae39f-8d85-11e9-b4a7-00505682dc8b",
"type": "check",
"state": "successful",
"start_time": "2019-06-14T11:15:00-07:00",
"end_time": "2019-06-14T11:16:08-07:00",
"href": "/api/cluster/metrocluster/operations/a14ae39f-8d85-11e9-b4a7-00505682dc8b"
"uuid": "7058df27-8d85-11e9-bbc9-005056826931",
"type": "configure",
"start_time": "2019-06-12T19:46:27-07:00",
"end_time": "2019-06-12T19:48:17-07:00",
"href": "/api/cluster/metrocluster/operations/7058df27-8d85-11e9-bbc9-005056826931"
"uuid": "7849515d-8d84-11e9-bbc9-005056826931",
"type": "connect",
"start_time": "2019-06-12T19:39:30-07:00",
"end_time": "2019-06-12T19:42:02-07:00",
"href": "/api/cluster/metrocluster/operations/7849515d-8d84-11e9-bbc9-005056826931"
"uuid": "331c79ad-8d84-11e9-b4a7-00505682dc8b",
"type": "interface_create",
"start_time": "2019-06-12T19:37:35-07:00",
"end_time": "2019-06-12T19:37:41-07:00",
"href": "/api/cluster/metrocluster/operations/331c79ad-8d84-11e9-b4a7-00505682dc8b"
"num_records": 4,
"href": "/api/cluster/metrocluster/operations?fields=%2A"
Retrieves Information about a specific MetroCluster operation
GET https://<mgmt-ip>/api/cluster/metrocluster/operations/0db12274-86fd-11e9-8053-00505682c342
"uuid": "0db12274-86fd-11e9-8053-00505682c342",
"name": "check",
"start_time": "2019-06-06T16:15:01-07:00",
"end_time": "2019-06-06T16:16:05-07:00",
"href": "/api/cluster/metrocluster/operations/0db12274-86fd-11e9-8053-00505682c342"
