REST API reference
Retrieve status for all automatic updates
Retrieve the status of all automatic package updates using this API. You can monitor the progress and completion of updates through supported GET calls.
Overview
Use this API to retrieve the status for all the automatic package updates.
This API only supports GET calls.
Retrieving the status of all package updates
The following example shows how to retrieve the status of all automatic updates:
# The API:
GET /support/auto-update/updates/
# The call:
curl -X GET "https://<mgmt-ip>/api/support/auto-update/updates?fields=*"
# The response:
"records": [
    "uuid" : "440ae2e4-fd8f-4225-9bee-94e2da3f8d9d",
    "package_id" : "572361f3-e769-439d-9c04-2ba48a08ff47",
    "content_type" : "disk_fw",
    "content_category" : "firmware",
    "description" : "disk_fw version 3.0",
    "state" : "downloading",
    "creation_time" : "2020-12-01T09:12:03Z",
    "expiry_time" : "2021-06-01T09:12:03Z",
    "last_state_change_time" : "2020-12-01T09:12:23Z",
    "start_time": "2020-12-01T09:12:23Z",
    "percent_complete": 25,
    "remaining_time": "PT1M30S",
        "href": "/support/auto-update/updates/440ae2e4-fd8f-4225-9bee-94e2da3f8d9d"
    "uuid" : "440ae2e4-fd8f-4225-9bee-94e2da3f9d8d",
    "package_id" : "e2e12753-8501-11e8-a7c1-00505695c997",
    "description" : "disk_fw version 3.1",
    "state" : "pending_confirmation",
    "uuid" : "440ae2e4-fd8f-4225-9aeb-94e2da3f8ef9",
    "content_type" : "shelf_fw",
    "content_category" : "Firmware",
    "description" : "shelf_fw version 4.0",
    "state" : "applying",
    "creation_time" : "2020-12-01T09:11:53Z",
    "last_state_change_time" : "2020-12-01T09:12:13Z",
    "percent_complete": 85,
    "remaining_time": "PT30S",
        "href": "/support/auto-update/updates/440ae2e4-fd8f-4225-9aeb-94e2da3f8ef9"
"num_records": 3,
    "href": "/api/support/auto-update/updates?fields=*"
