View and manage cluster jobs
Use this API to view and manage asynchronous operations within your cluster, known as jobs. You can retrieve job information, update job states, and handle long-running tasks by pausing or canceling them through PATCH requests.
Overview
You can use this API to view and manipulate jobs. Jobs provide information about asynchronous operations. Some long-running jobs are paused or cancelled by calling a PATCH request. Individual operations indicate if they support PATCH requests on the job. After a job transitions to a terminal state, it is deleted after a default time of 300 seconds. Attempts to call a GET or PATCH request on the job returns a 404 error code After the job has been deleted.
Example
The following examples show how to retrieve and update a job state:
Retrieving job information
# The API:
/api/cluster/jobs/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/jobs/b5145e1d-b53b-11e8-8252-005056bbd8f5" -H "accept: application/json"
# The response:
"uuid": "b5145e1d-b53b-11e8-8252-005056bbd8f5",
"code": 0,
"description": "Cluster Backup Job",
"state": "running",
"message": "creating_node_backups",
"href": "/api/cluster/jobs/b5145e1d-b53b-11e8-8252-005056bbd8f5"
Updating a job that supports the new state
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/cluster/jobs/b5145e1d-b53b-11e8-8252-005056bbd8f5?action=cancel" -H "accept: application/json"
