REST API reference
View lock details
Overview
A lock is a synchronization mechanism for enforcing limits on concurrent access to files where many clients can be accessing the same file at the same time. Locks can be viewed or broken according to a wide range of query fields that are presented in the lock information definition.
It is recommended that you provide as many fields as possible to optimize query processing.
Retrieving locks with all fields for all SVMs
# The API:
GET /protocols/locks
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/locks?return_records=true&return_timeout=15&fields=*" -H "accept: application/json"
# The response:
"records": [
    "svm": {
      "uuid": "5b4b6847-9ae4-11eb-8597-0050568ec154",
      "name": "vs1"
    "volume": {
      "uuid": "429dcc79-9af2-11eb-b313-0050568ec154",
      "name": "test_vol1"
    "interface": {
      "name": "vs1.data",
      "uuid": "6bf26e25-9ae4-11eb-8597-0050568ec154",
      "ip": {
        "address": "10.140.115.95"
    "path": "/test_vol1/Demo406.TXT",
    "uuid": "bf03d8b4-e145-498a-902d-b9fe5d546d18",
    "constituent": false,
    "protocol": "cifs",
    "client_address": "10.74.7.22",
    "owner_id": "feff-0206000000020000000204000000000000000000000000ffff0a4a07161053010001000000030000006c00000000000000",
    "share_lock": {
      "mode": "read_write_deny_write_delete",
      "soft": false
    "smb": {
      "connect_state": "connected",
      "open_group_id": "71756e2325a7eb11843f005056a4731c101068450bcdffff1c2c000000000000",
      "open_type": "durable"
    "state": "granted",
    "type": "share_level",
    "node": {
      "name": "bshalini-vsim3",
      "uuid": "1f29b875-9ae3-11eb-8597-0050568ec154"
    "svm": {
      "name": "vs1"
    "volume": {
      "name": "test_vol1"
    "interface": {
      "name": "vs1.data",
      "ip": {
    "uuid": "0c33d18d-dcbc-492a-81b3-4c5740c46172",
    "protocol": "cifs",
    "oplock_level": "batch",
    "smb": {
    "state": "granted",
    "type": "op_lock",
    "node": {
"num_records": 2
Retrieving locks of a specific volume
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/locks?volume.uuid=429dcc79-9af2-11eb-b313-0050568ec154&return_records=true&return_timeout=15&fields=*" -H "accept: application/json"
# The response:
"records": [
    "svm": {
      "name": "vs1"
    "volume": {
      "name": "test_vol1"
    "interface": {
      "name": "vs1.data",
    "path": "/test_vol1/Demo408.TXT",
    "uuid": "be1cdf00-37f1-4477-b6d0-bba8c4fa8c67"
    "svm": {
      "name": "vs1"
    "volume": {
      "name": "test_vol1"
    "interface": {
      "name": "vs1.data",
    "uuid": "393cc06e-8b37-4f49-b09a-74d1eef79368"
"num_records": 2
Retrieving the lock for a specific UUID
# The API:
GET /protocols/locks/{uuid}
# The call:
curl  -X GET "https://<mgmt-ip>/api/protocols/locks/be1cdf00-37f1-4477-b6d0-bba8c4fa8c67" -H "accept: application/json"
# The response:
"svm": {
  "name": "vs1"
"volume": {
  "name": "test_vol1"
"interface": {
  "name": "vs1.data",
  "ip": {
"uuid": "be1cdf00-37f1-4477-b6d0-bba8c4fa8c67",
"protocol": "cifs",
"share_lock": {
  "soft": false
"smb": {
"state": "granted",
"node": {
Deleting the lock for a specific UUID
# The API:
DELETE /protocols/locks/{uuid}
# The call:
curl  -X DELETE "https://<mgmt-ip>/api/protocols/locks/be1cdf00-37f1-4477-b6d0-bba8c4fa8c67" -H "accept: application/json"
Deleting all locks for a specific protocol
# The API:
# The call:
curl  -X DELETE "https://<mgmt-ip>/api/protocols/locks?protocol=cifs" -H "accept: application/json"
