Delete a user from a UNIX group
Removes a user from a specific UNIX group when you need to update group memberships.
HTTP method and endpoint
DELETE /name-services/unix-groups/{svm.uuid}/{unix_group.name}/users/{name}
Introduced in
ONTAP 9.9
Usage notes
Deletes a user from the specified UNIX group.
Related ONTAP commands
vserver services name-service unix-group deluser
unix_group.name |
string |
path |
True |
UNIX group name. |
name |
string |
path |
True |
UNIX user to be deleted from the group. |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
3276897 |
The specified UNIX group does not exist in the SVM. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
