Delete a tag for a resource
Deletes a specific tag from a resource when you need to remove its association or categorization.
HTTP method and endpoint
DELETE /resource-tags/{resource_tag.value}/resources/{href}
Introduced in
ONTAP 9.13
Usage notes
Deletes a specific tag on a specific resource.
resource_tag.value |
string |
path |
True |
href |
string |
path |
True |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
