Delete a Duo group configured for an SVM or cluster
Removes a Duo group configured for an SVM or cluster when it is no longer needed for authentication or access control.
HTTP method and endpoint
DELETE /security/authentication/duo/groups/{owner.uuid}/{name}
Introduced in
ONTAP 9.14
Usage notes
Deletes a Duo group of the SVM or cluster.
Related ONTAP commands
security login duo group delete
owner.uuid |
string |
path |
True |
Account owner UUID. |
name |
string |
path |
True |
Group name. |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
