REST API reference
Delete the TOTP profile for a user account
Deletes the TOTP profile associated with a user account when you need to remove two-factor authentication settings for that account.
HTTP method and endpoint
DELETE /security/login/totps/{owner.uuid}/{account.name}
Introduced in
ONTAP 9.13
Usage notes
Deletes the TOTP profile for a user account.
  • security login totp delete
owner.uuid
string
path
True
Account owner UUID.
account.name
string
path
True
Account user name.
Status: 200, Ok
Status: Default, Error
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
