REST API reference
Retrieve counter table details
Accesses details about a specific counter table, providing information necessary for monitoring and analysis.
HTTP method and endpoint
GET /cluster/counter/tables/{name}
Introduced in
ONTAP 9.11
Usage notes
Returns the information about a single counter table.
name
string
path
True
Counter table name.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
counter_schemas
array[counter_schema]
Array of counter schema definitions.
description
string
Description of the table.
name
string
Table name.
      "href": "/api/resourcelink"
  "counter_schemas": [
      "denominator": {
        "name": "string"
      "description": "string",
      "name": "string",
      "type": "string",
      "unit": "string"
  "name": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
8585320
Table requested is not found
8585368
The system has not completed it's initialization
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
counter_denominator
Counter used as the denominator in calculating the resulting value of averages and percentages.
name
string
Counter name.
counter_schema
Schema definition of a single counter or property.
denominator
counter_denominator
description
string
Counter or property description.
name
string
Counter or property name.
type
string
Type of counter or property. Properties will always set this field to 'string'.
unit
string
Counter unit.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
