REST API reference
Retrieve unapplied group policy objects for an SVM
Retrieves unapplied group policy objects for a specified SVM to identify which policies are still pending application.
HTTP method and endpoint
GET /protocols/cifs/group-policies/{svm.uuid}
Introduced in
ONTAP 9.12
Usage notes
Retrieves group policy objects that are yet to be applied for specified SVM.
  • vserver cifs group-policy show-defined
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
svm
svm
to_be_applied
to_be_applied
  "svm": {
        "href": "/api/resourcelink"
    "name": "svm1",
  "to_be_applied": {
    "access_policies": [
        "create_time": "2018-01-01 11:00:00 -0500",
        "description": "policy #1",
        "member_rules": [
          "r1",
          "r2"
        "name": "p1",
        "sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
        "svm": {
          "name": "svm1",
        "update_time": "2018-01-01 11:00:00 -0500"
    "access_rules": [
        "current_permission": "O:SYG:SYD:AR(A;;FA;;;WD)",
        "description": "rule #1",
        "name": "p1",
        "proposed_permission": "O:SYG:SYD:(A;;FA;;;OW)(A;;FA;;;BA)(A;;FA;;;SY)",
        "resource_criteria": "department",
        "svm": {
          "name": "svm1",
    "objects": [
        "central_access_policy_settings": [
          "p1",
          "p2"
        "central_access_policy_staging_audit_type": "none",
        "extensions": [
          "audit",
          "security"
        "file_system_path": "\\test.com\\SysVol\\test.com\\policies\\{42474212-3f9d-4489-ae01-6fcf4f805d4c}",
        "index": 1,
        "ldap_path": "cn={42474212-3f9d-4489-ae01-6fcf4f805d4c},cn=policies,cn=system,DC=TEST,DC=COM",
        "link": "domain",
        "name": "test_policy",
        "registry_settings": {
          "branchcache": {
            "hash_publication_mode": "disabled",
            "supported_hash_version": "version1"
          "refresh_time_interval": "P15M",
          "refresh_time_random_offset": "P1D"
        "security_settings": {
          "event_audit_settings": {
            "logon_type": "failure",
            "object_access_type": "failure"
          "event_log_settings": {
            "max_size": 2048,
            "retention_method": "do_not_overwrite"
          "files_or_folders": [
            "/vol1/home",
            "/vol1/dir1"
          "kerberos": {
            "max_clock_skew": "P15M",
            "max_renew_age": "P2D",
            "max_ticket_age": "P24H"
          "privilege_rights": {
            "change_notify_users": [
              "usr1",
              "usr2"
            "security_privilege_users": [
              "usr1",
              "usr2"
            "take_ownership_users": [
              "usr1",
              "usr2"
          "restrict_anonymous": {
            "combined_restriction_for_anonymous_user": "no_access"
          "restricted_groups": [
            "test_grp1",
            "test_grp2"
        "svm": {
          "name": "svm1",
        "uuid": "42474212-3f9d-4489-ae01-6fcf4f805d4c",
        "version": 7
        "group_name": "test_group",
        "link": "domain",
        "members": [
          "DOMAIN/test_user",
          "DOMAIN/user2"
        "memberships": [
          "DOMAIN/AdministratorGrp",
          "DOMAIN/deptMark"
        "policy_name": "test_policy",
        "svm": {
          "name": "svm1",
        "version": 7
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
uuid
string
svm
Will not be populated for objects that are yet to be applied.
_links
_links
name
string
uuid
string
group_policy_object_central_access_policy
create_time
string
Policy creation timestamp.
description
string
Description about the policy.
member_rules
array[string]
Names of all central access rules applied to members.
name
string
sid
string
Security ID, unique identifier of the central policy.
svm
svm
update_time
string
Last policy modification timestamp.
group_policy_object_central_access_rule
create_time
string
current_permission
string
Effective security policy in security descriptor definition language format.
description
string
name
string
proposed_permission
string
Proposed security policy in security descriptor definition language format.
resource_criteria
string
Criteria to scope resources for which access rules apply.
svm
svm
update_time
string
group_policy_object_branchcache
string
Hash publication mode.
string
Hash version.
group_policy_object_registry_setting
branchcache
string
Refresh time interval in ISO-8601 format.
string
Random offset in ISO-8601 format.
group_policy_object_event_audit
logon_type
string
Type of logon event to be audited.
object_access_type
string
Type of object access to be audited.
group_policy_object_event_log
max_size
integer
Maximum size of security log, in kilobytes.
retention_method
string
Audit log retention method.
group_policy_object_kerberos
max_clock_skew
string
Kerberos clock skew in ISO-8601 format.
max_renew_age
string
Kerberos max renew age in ISO-8601 format.
max_ticket_age
string
Kerberos max ticket age in ISO-8601 format.
group_policy_object_privilege_right
change_notify_users
array[string]
Users with traversing bypass privileges.
array[string]
Users with security privileges.
array[string]
Users who can take ownership of securable objects.
group_policy_object_registry_value
signing_required
boolean
SMB signing required.
group_policy_object_restrict_anonymous
anonymous_access_to_shares_and_named_pipes_restricted
boolean
Restrict anonymous access to shares and named pipes.
string
Combined restriction for anonymous user.
no_enumeration_of_sam_accounts
boolean
No enumeration of SAM accounts.
no_enumeration_of_sam_accounts_and_shares
boolean
No enumeration of SAM accounts and shares.
group_policy_object_security_setting
event_log_settings
files_or_folders
array[string]
Files/Directories for file security.
kerberos
privilege_rights
registry_values
restrict_anonymous
restricted_groups
array[string]
List of restricted groups.
group_policy_object
array[string]
List of central access policies.
string
Types of events to be audited.
enabled
boolean
Specifies whether group policies are enabled for the SVM.
extensions
array[string]
List of extensions.
file_system_path
string
File system path.
index
integer
Group policy object index.
ldap_path
string
LDAP path to the GPO.
link
string
Link info.
name
string
registry_settings
security_settings
svm
svm
uuid
string
Policy UUID.
version
integer
Group policy object version.
group_policy_object_restricted_group
group_name
string
link
string
Link info.
members
array[string]
Members of the group.
memberships
array[string]
Group is member of Group/OU.
policy_name
string
svm
svm
version
integer
to_be_applied
access_policies
array[group_policy_object_central_access_policy]
access_rules
array[group_policy_object_central_access_rule]
objects
array[group_policy_object]
restricted_groups
array[group_policy_object_restricted_group]
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
