REST API reference
Retrieve an applied central access policy for an SVM
Retrieves the applied central access policy for a specified SVM to review its current configuration.
HTTP method and endpoint
GET /protocols/cifs/group-policies/{svm.uuid}/central-access-policies/{name}
Introduced in
ONTAP 9.12
  • vserver cifs group-policy central-access-policy show-applied
name
string
path
True
Central access policy name.
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
create_time
string
Policy creation timestamp.
description
string
Description about the policy.
member_rules
array[string]
Names of all central access rules applied to members.
name
string
sid
string
Security ID, unique identifier of the central policy.
svm
svm
Will not be populated for objects that are yet to be applied.
update_time
string
Last policy modification timestamp.
  "create_time": "2018-01-01 11:00:00 -0500",
  "description": "policy #1",
  "member_rules": [
    "r1",
    "r2"
  "name": "p1",
  "sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
  "svm": {
        "href": "/api/resourcelink"
    "name": "svm1",
  "update_time": "2018-01-01 11:00:00 -0500"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
