REST API reference
Retrieve an applied group policy object for an SVM
Retrieves the applied group policy object for a specified SVM to review its configuration details.
HTTP method and endpoint
GET /protocols/cifs/group-policies/{svm.uuid}/objects/{index}
Introduced in
ONTAP 9.12
  • vserver cifs group-policy show-applied
index
integer
path
True
Restricted group index.
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
central_access_policy_settings
array[string]
List of central access policies.
central_access_policy_staging_audit_type
string
Types of events to be audited.
enabled
boolean
Specifies whether group policies are enabled for the SVM.
extensions
array[string]
List of extensions.
file_system_path
string
File system path.
index
integer
Group policy object index.
ldap_path
string
LDAP path to the GPO.
link
string
Link info.
name
string
registry_settings
group_policy_object_registry_setting
security_settings
group_policy_object_security_setting
svm
svm
Will not be populated for objects that are yet to be applied.
uuid
string
Policy UUID.
version
integer
Group policy object version.
  "central_access_policy_settings": [
    "p1",
    "p2"
  "central_access_policy_staging_audit_type": "none",
  "extensions": [
    "audit",
    "security"
  "file_system_path": "\\test.com\\SysVol\\test.com\\policies\\{42474212-3f9d-4489-ae01-6fcf4f805d4c}",
  "index": 1,
  "ldap_path": "cn={42474212-3f9d-4489-ae01-6fcf4f805d4c},cn=policies,cn=system,DC=TEST,DC=COM",
  "link": "domain",
  "name": "test_policy",
  "registry_settings": {
    "branchcache": {
      "hash_publication_mode": "disabled",
      "supported_hash_version": "version1"
    "refresh_time_interval": "P15M",
    "refresh_time_random_offset": "P1D"
  "security_settings": {
    "event_audit_settings": {
      "logon_type": "failure",
      "object_access_type": "failure"
    "event_log_settings": {
      "max_size": 2048,
      "retention_method": "do_not_overwrite"
    "files_or_folders": [
      "/vol1/home",
      "/vol1/dir1"
    "kerberos": {
      "max_clock_skew": "P15M",
      "max_renew_age": "P2D",
      "max_ticket_age": "P24H"
    "privilege_rights": {
      "change_notify_users": [
        "usr1",
        "usr2"
      "security_privilege_users": [
        "usr1",
        "usr2"
      "take_ownership_users": [
        "usr1",
        "usr2"
    "restrict_anonymous": {
      "combined_restriction_for_anonymous_user": "no_access"
    "restricted_groups": [
      "test_grp1",
      "test_grp2"
  "svm": {
        "href": "/api/resourcelink"
    "name": "svm1",
  "uuid": "42474212-3f9d-4489-ae01-6fcf4f805d4c",
  "version": 7
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
group_policy_object_branchcache
string
Hash publication mode.
string
Hash version.
branchcache
string
Refresh time interval in ISO-8601 format.
string
Random offset in ISO-8601 format.
group_policy_object_event_audit
logon_type
string
Type of logon event to be audited.
object_access_type
string
Type of object access to be audited.
group_policy_object_event_log
max_size
integer
Maximum size of security log, in kilobytes.
retention_method
string
Audit log retention method.
group_policy_object_kerberos
max_clock_skew
string
Kerberos clock skew in ISO-8601 format.
max_renew_age
string
Kerberos max renew age in ISO-8601 format.
max_ticket_age
string
Kerberos max ticket age in ISO-8601 format.
group_policy_object_privilege_right
change_notify_users
array[string]
Users with traversing bypass privileges.
array[string]
Users with security privileges.
array[string]
Users who can take ownership of securable objects.
group_policy_object_registry_value
signing_required
boolean
SMB signing required.
group_policy_object_restrict_anonymous
anonymous_access_to_shares_and_named_pipes_restricted
boolean
Restrict anonymous access to shares and named pipes.
string
Combined restriction for anonymous user.
no_enumeration_of_sam_accounts
boolean
No enumeration of SAM accounts.
no_enumeration_of_sam_accounts_and_shares
boolean
No enumeration of SAM accounts and shares.
event_log_settings
files_or_folders
array[string]
Files/Directories for file security.
kerberos
privilege_rights
registry_values
restrict_anonymous
restricted_groups
array[string]
List of restricted groups.
string
self
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
