REST API reference
Retrieve UNIX symbolic link mappings for CIFS clients
GET /protocols/cifs/unix-symlink-mapping
Introduced In: 9.6
Retrieves UNIX symbolic link mappings for CIFS clients.
  • vserver cifs symlink show
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
unix_path
string
query
False
Filter by unix_path
  • maxLength: 256
target.path
string
query
False
Filter by target.path
  • maxLength: 256
target.locality
string
query
False
Filter by target.locality
target.home_directory
boolean
query
False
Filter by target.home_directory
target.share
string
query
False
Filter by target.share
  • maxLength: 80
target.server
string
query
False
Filter by target.server
  • maxLength: 45
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[cifs_symlink_mapping]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "svm": {
        "name": "svm1",
      "target": {
        "locality": "string",
        "path": "/dir1/dir2/",
        "server": "ENGCIFS",
        "share": "ENG_SHARE"
      "unix_path": "/mnt/eng_volume/"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
uuid
string
cifs_target
home_directory
boolean
Specify if the destination share is a home directory.
locality
string
Specifies whether the CIFS symbolic link is a local link or wide link. The following values are supported:
  • local - Local symbolic link maps only to the same CIFS share.
  • widelink - Wide symbolic link maps to any CIFS share on the network.
path
string
Specifies the CIFS path on the destination to which the symbolic link maps. The final path is generated by concatenating the CIFS server name, the share name, the cifs-path and the remaining path in the symbolic link left after the prefix match. This value is specified by using a UNIX-style path name. The trailing forward slash is required for the full path name to be properly interpreted.
server
string
Specifies the destination CIFS server where the UNIX symbolic link is pointing. This field is mandatory if the locality of the symbolic link is 'widelink'. You can specify the value in any of the following formats:
  • DNS name of the CIFS server.
  • IP address of the CIFS server.
  • NetBIOS name of the CIFS server.
share
string
Specifies the CIFS share name on the destination CIFS server to which the UNIX symbolic link is pointing.
ONTAP allows for both CIFS and NFS access to the same datastore. This datastore can contain symbolic links created by UNIX clients which can point anywhere from the perspective of the UNIX client. To Access such UNIX symlink from CIFS share, we need to create a CIFS symbolic link path mapping from a UNIX symlink and target it as a CIFS path.
_links
_links
svm
svm
target
cifs_target
unix_path
string
Specifies the UNIX path prefix to be matched for the mapping.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
