REST API reference
Retrieve the Vscan scanner-pool configuration for an SVM
Accesses the Vscan scanner-pool configuration for a specific SVM to review its setup details. This is useful when assessing or auditing the virus scanning configuration linked to your storage resources.
HTTP method and endpoint
GET /protocols/vscan/{svm.uuid}/scanner-pools
Introduced in
ONTAP 9.6
Usage notes
Retrieves the Vscan scanner-pool configuration of an SVM.
  • vserver vscan scanner-pool show
  • vserver vscan scanner-pool privileged-users show
  • vserver vscan scanner-pool servers show
servers
string
query
False
Filter by servers
svm.name
string
query
False
Filter by svm.name
  • Introduced in: 9.10
name
string
query
False
Filter by name
  • maxLength: 256
  • minLength: 1
privileged_users
string
query
False
Filter by privileged_users
role
string
query
False
Filter by role
cluster.uuid
string
query
False
Filter by cluster.uuid
cluster.name
string
query
False
Filter by cluster.name
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[vscan_scanner_pool]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "cluster": {
        "name": "cluster1",
      "name": "scanner-1",
      "privileged_users": [
        "cifs\\u1",
        "cifs\\u2"
      "role": "string",
      "servers": [
        "1.1.1.1",
        "10.72.204.27",
        "vmwin204-27.fsct.nb"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
cluster_reference
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
uuid
string
vscan_scanner_pool
Scanner pool is a set of attributes which are used to validate and manage connections between clustered ONTAP and external virus-scanning server, or "Vscan server".
cluster
cluster_reference
name
string
Specifies the name of the scanner pool. Scanner pool name can be up to 256 characters long and is a string that can only contain any combination of ASCII-range alphanumeric characters a-z, A-Z, 0-9), "_", "-" and ".".
privileged_users
array[string]
Specifies a list of privileged users. A valid form of privileged user-name is "domain-name\user-name". Privileged user-names are stored and treated as case-insensitive strings. Virus scanners must use one of the registered privileged users for connecting to clustered Data ONTAP for exchanging virus-scanning protocol messages and to access file for scanning, remedying and quarantining operations.
  • example: ["cifs\u1", "cifs\u2"]
  • Introduced in: 9.6
role
string
Specifies the role of the scanner pool. The possible values are:
  • primary - Always active.
  • secondary - Active only when none of the primary external virus-scanning servers are connected.
  • idle - Always inactive.
servers
array[string]
Specifies a list of IP addresses or FQDN for each Vscan server host names which are allowed to connect to clustered ONTAP.
  • example: ["1.1.1.1", "10.72.204.27", "vmwin204-27.fsct.nb"]
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
