REST API reference
Retrieve a resource tag
Retrieves a specific resource tag to access its detailed information and manage tagging for resources efficiently.
HTTP method and endpoint
GET /resource-tags/{value}
Introduced in
ONTAP 9.13
value
string
path
True
  • format: key:value
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
num_resources
integer
The number of resources that are currently using this tag.
value
string
A key:value formatted string representing the tag's name.
  "value": "team:accounting"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
