REST API reference
Retrieve a plex specified by the aggregate UUID and plex name
Retrieves a specific plex by its aggregate UUID and plex name to access detailed information about that plex.
HTTP method and endpoint
GET /storage/aggregates/{aggregate.uuid}/plexes/{name}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the plex specified by the aggregate UUID and plex name.
  • storage aggregate plex show
aggregate.uuid
string
path
True
Aggregate UUID
name
string
path
True
Plex name
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
aggregate
aggregate
Aggregate
name
string
Plex name
online
boolean
Plex is online
pool
string
SyncMirror pool assignment
raid_groups
array[raid_group]
resync
resync
state
string
Plex state
  "aggregate": {
        "href": "/api/resourcelink"
    "name": "aggr1",
  "name": "plex0",
  "pool": "string",
  "raid_groups": [
      "disks": [
          "disk": {
            "name": "1.0.1"
          "position": "string",
          "state": "string",
          "type": "ssd",
          "usable_size": 947912704
      "name": "rg0",
      "raid_type": "raid_dp",
      "recomputing_parity": {
        "percent": 10
      "reconstruct": {
        "percent": 10
  "resync": {
    "level": "string",
    "percent": 10
  "state": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
aggregate
Aggregate
_links
_links
name
string
uuid
string
disk
Disk
_links
_links
name
string
raid_group_disk
disk
disk
Disk
position
string
The position of the disk within the RAID group.
state
string
The state of the disk within the RAID group.
type
string
Disk interface type
usable_size
integer
Size in bytes that is usable by the aggregate.
recomputing_parity
active
boolean
RAID group is recomputing parity
percent
integer
Recomputing parity percentage
reconstruct
active
boolean
One or more disks in this RAID group are being reconstructed.
percent
integer
Reconstruct percentage
raid_group
cache_tier
boolean
RAID group is a cache tier
degraded
boolean
RAID group is degraded. A RAID group is degraded when at least one disk from that group has failed or is offline.
disks
array[raid_group_disk]
name
string
RAID group name
raid_type
string
RAID type of the raid group.
recomputing_parity
recomputing_parity
reconstruct
reconstruct
resync
active
boolean
Plex is being resynchronized to its mirrored plex
level
string
Plex resyncing level
percent
integer
Plex resyncing percentage
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
