REST API reference
Retrieve a QoS workload
GET /storage/qos/workloads/{uuid}
Introduced In: 9.10
Retrieves a specific QoS workload.
  • qos workload show
uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
file
string
Name of the file.
lun
string
Name of the LUN. The name of the LUN will be displayed as "(unknown)" if the name cannot be retrieved.
name
string
Name of the QoS workload.
policy
policy
QoS policy group reference.
qtree
string
Name of the Qtree.
svm
svm
uuid
string
volume
string
Name of the volume. The name of the volume will be displayed as "(unknown)" if the name cannot be retrieved.
wid
integer
Workload ID of the QoS workload.
workload_class
string
Class of the QoS workload.
      "href": "/api/resourcelink"
  "file": "string",
  "lun": "string",
  "name": "volume1-wid123",
  "policy": {
    "name": "performance",
  "qtree": "string",
  "svm": {
    "name": "svm1",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "volume": "volume1",
  "wid": 123,
  "workload_class": "autovolume"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
policy
_links
_links
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
