Retrieve quota policy rule properties
GET /storage/quota/rules/{uuid}
Introduced In: 9.7
Retrieves properties for a specific quota policy rule.
Related ONTAP commands
quota policy rule show
uuid  |
string  |
path  |
True  |
Rule UUID  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
files  |
group  |
This parameter specifies the target group to which the group quota policy rule applies. This parameter takes a group name or identifier. This parameter is only valid for the POST operation of a group quota policy rule. The POST operation will fail with an appropriate error if this parameter is used as an input to create a user or a tree quota policy rule. This input parameter for POST takes either a group name or a group identifier, but not both. For default quota rules, the group name must be chosen and should be specified as "". For explicit group quota rules, this parameter can contain a UNIX group name or a UNIX group identifier.  |
qtree  |
This parameter specifies the target qtree to which the user/group/tree quota policy rule applies. For a user/group quota policy rule at qtree level, this parameter takes a qtree name and is valid in GET or POST. For a user/group quota policy rule at volume level, this parameter is not valid in GET or POST. For a tree quota policy rule, this parameter is mandatory and is valid in both POST and GET. For a default tree quota policy rule, this parameter needs to be specified as "". For a tree quota policy rule at qtree level, this parameter takes a qtree name and is valid in GET or POST.  |
space  |
svm  |
SVM, applies only to SVM-scoped objects.  |
type  |
string  |
This parameter specifies the quota policy rule type. This is required in POST only and can take either one of the "user", "group" or "tree" values.  |
user_mapping  |
boolean  |
This parameter enables user mapping for user quota policy rules. This is valid in POST or PATCH for user quota policy rules only.  |
users  |
array[users]  |
This parameter specifies the target user to which the user quota policy rule applies. This parameter takes single or multiple user names or identifiers. This parameter is valid only for the POST operation of a user quota policy rule. If this parameter is used as an input to create a group or a tree quota policy rule, the POST operation will fail with an appropriate error. For POST, this input parameter takes either a user name or a user identifier, not both. For default quota rules, the user name must be chosen and specified as "". For explicit user quota rules, this parameter can indicate either a user name or user identifier. The user name can be a UNIX user name or a Windows user name. If a name contains a space, enclose the entire value in quotes. A UNIX user name cannot include a backslash () or an @ sign; user names with these characters are treated as Windows names. The user identifer can be a UNIX user identifier or a Windows security identifier. For multi-user quota, this parameter can contain multiple user targets separated by a comma.  |
uuid  |
string  |
Unique identifier for the quota policy rule. This field is generated when the quota policy rule is created.  |
volume  |
      "href": "/api/resourcelink"
  "group": {
    "id": "string",
    "name": "string"
  "qtree": {
    "id": 1,
    "name": "qt1"
  "svm": {
    "name": "svm1",
  "type": "string",
  "users": [
      "id": "string",
      "name": "string"
  "uuid": "5f1d13a7-f401-11e8-ac1a-005056a7c3b9",
  "volume": {
    "name": "volume1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5308544  |
The specified quota rule UUID is invalid.  |
5308545  |
Unable to retrieve rule for the specified quota rule UUID.  |
5308576  |
Parameter   |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
files
hard_limit  |
integer  |
This parameter specifies the hard limit for files. This is valid in POST or PATCH.  |
soft_limit  |
integer  |
This parameter specifies the soft limit for files. This is valid in POST or PATCH.  |
group
id  |
string  |
Quota target group ID  |
name  |
string  |
Quota target group name  |
qtree
_links  |
id  |
integer  |
The unique identifier for a qtree.  |
name  |
string  |
The name of the qtree.  |
space
hard_limit  |
integer  |
This parameter specifies the space hard limit, in bytes. If less than 1024 bytes, the value is rounded up to 1024 bytes. Valid in POST or PATCH. For a POST operation where the parameter is either empty or set to -1, no limit is applied. For a PATCH operation where a limit is configured, use a value of -1 to clear the limit.  |
soft_limit  |
integer  |
This parameter specifies the space soft limit, in bytes. If less than 1024 bytes, the value is rounded up to 1024 bytes. Valid in POST or PATCH. For a POST operation where the parameter is either empty or set to -1, no limit is applied. For a PATCH operation where a limit is configured, use a value of -1 to clear the limit.  |
svm
_links  |
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
users
id  |
string  |
Quota target user ID  |
name  |
string  |
Quota target user name  |
volume
_links  |
name  |
string  |
The name of the volume. This field cannot be specified in a POST or PATCH method.  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
