Retrieve SVM properties
Retrieves the properties of an individual SVM, including configurations for protocols like CIFS and NFS, export policies, name service configurations, and network services. This allows you to understand and manage the specific settings and capabilities of the SVM.
HTTP method and endpoint
GET /svm/svms/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the properties for an individual SVM. This includes protocol configurations such as CIFS and NFS, export policies, name service configurations, and network services.
Important notes
The SVM object includes a large set of fields and can be expensive to retrieve.
REST APIs only expose a data SVM as an SVM.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
snapmirror.*
Example
Retrieving an individual SVM in the cluster
GET "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485"
uuid |
string |
path |
True |
Filter by UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
aggregates |
array[aggregates] |
List of allowed aggregates for SVM volumes. An administrator is allowed to create volumes on these aggregates. |
aggregates_delegated |
boolean |
This property is true when the administrator has delegated the aggregates for the SVM volumes. |
anti_ransomware |
Anti-ransomware related information for the SVM. |
anti_ransomware_auto_switch_duration_without_new_file_extension |
integer |
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that no new file-extensions are observed in the volume in recent time. This parameter optionally specifies the recent time duration (in days) to be considered during which no new file-extension should be observed in a given volume to automatically switch the anti-ransomware state from '`learning`" to “enabled”. |
anti_ransomware_auto_switch_from_learning_to_enabled |
boolean |
This property specifies whether anti-ransomware state of the volumes in this SVM are automatically switched by the system from “learning” (dry-run) to “enabled” (active) state after sufficient learning. |
anti_ransomware_auto_switch_minimum_file_count |
integer |
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should have a minimum file count in “learning” state. This parameter optionally specifies the minimum number of newly created files in “learning” state in a given volume to automatically switch the anti-ransomware state from “learning” to “enabled”. |
anti_ransomware_auto_switch_minimum_file_extension |
integer |
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should have minimum number of file extensions in “learning” state. This parameter optionally specifies the minimum number of new file extensions in “learning” state in a given volume to automatically switch the anti-ransomware state from “learning” to “enabled”. |
anti_ransomware_auto_switch_minimum_learning_period |
integer |
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should be in “learning” state for sufficient time period. This parameter optionally specifies the minimum number of days a given volume should be in “learning” state to automatically switch the anti-ransomware state from “learning” to “enabled”. |
anti_ransomware_default_volume_state |
string |
Specifies the default Anti-ransomware state of the volumes in the SVM. Default "anti_ransomware_default_volume_state" property is disabled for POST operation. If this value is "disabled", Anti-ransomware protection is disabled by default on the new volumes that are created in the SVM. If this value is "dry_run", Anti-ransomware protection is in learning mode by default on the new volumes that are created in the SVM. When the Anti-ransomware license is not present, this property is ignored and volumes will be created with the "disabled" state. |
anti_ransomware_incoming_write_threshold |
string |
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should have sufficient data ingested to do the learning. This parameter optionally specifies the minimum amount of data (in GB) to be written to a given volume during the learning period to automatically switch the anti-ransomware state from “learning” to “enabled”. The amount of data considered as ingested also includes the data that is deleted or overwritten after ingestion. |
anti_ransomware_incoming_write_threshold_percent |
string |
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this SVM from “learning” (dry-run) to “enabled” is that the volume should have sufficient data ingested to do the learning. This parameter optionally specifies the minimum amount of data (in percentage) to be written to a given volume during the learning period to automatically switch the anti-ransomware state from “learning” to “enabled”. The amount of data considered as ingested also includes the data that is deleted or overwritten after ingestion. |
auto_enable_activity_tracking |
boolean |
Specifies whether volume activity tracking is automatically enabled on volumes that are created in the SVM. |
auto_enable_analytics |
boolean |
Specifies whether file system analytics is automatically enabled on volumes that are created in the SVM. |
certificate |
Support for this field will be removed in a future release. Please use /svm/svms/{svm.uuid}/web for this field. Certificate for incoming TLS connection requests. |
cifs |
comment |
string |
Comment |
dns |
fc_interfaces |
array[fc_interface_svm] |
FC Interface for the SVM |
fcp |
ip_interfaces |
array[ip_interface_svm] |
IP interfaces for the SVM |
ipspace |
Either the UUID or name may be supplied on input. |
is_space_enforcement_logical |
boolean |
Indicates whether logical space enforcement for the SVM is enabled. |
is_space_reporting_logical |
boolean |
Indicates whether logical space reporting for the SVM is enabled. |
iscsi |
language |
string |
Default volume language code. UTF-8 encoded languages are valid in POST or PATCH. Non UTF-8 language encodings are for backward compatibility and are not valid input for POST and PATCH requests. |
ldap |
max_volumes |
string |
This property is used by cluster administrator to specify the limit on maximum number of volumes allowed in the SVM. The value can be either the string "unlimited" or a number. |
name |
string |
The name of the SVM. |
ndmp |
nfs |
nis |
nsswitch |
Name service switch configuration |
number_of_volumes_in_recovery_queue |
integer |
Number of volumes in the recovery queue. |
nvme |
qos_adaptive_policy_group_template |
This optionally specifies which QoS adaptive policy group to apply to the SVM as a template. This policy group will then be assigned to volumes created or rehosted into this SVM. This policy group defines measurable service level objectives (SLOs) and Service Level Agreements (SLAs) that adjust based on the volume allocated space or used space. |
qos_policy |
This optionally specifies which QoS policy group to apply to the Vserver. This policy group defines measurable service level objectives (SLOs) that apply to the storage objects with which the policy group is associated. |
s3 |
snapmirror |
Specifies attributes for SVM DR protection. |
snapshot_policy |
This is a reference to the Snapshot copy policy. |
state |
string |
SVM State |
storage |
subtype |
string |
SVM subtype. The SVM subtype sync_destination is created automatically when an SVM of subtype sync_source is created on the source MetroCluster cluster. A POST request with sync_destination as SVM subtype is invalid. |
total_volume_size_in_recovery_queue |
integer |
Sum of the sizes of the volumes in the recovery queue. |
uuid |
string |
"href": "/api/resourcelink"
"aggregates": [
"available_size": 10156560384,
"name": "aggr1",
"snaplock_type": "string",
"state": "string",
"type": "string",
"anti_ransomware_default_volume_state": "string",
"anti_ransomware_incoming_write_threshold": "string",
"anti_ransomware_incoming_write_threshold_percent": "string",
"certificate": {
"name": "string",
"cifs": {
"ad_domain": {
"default_site": "string",
"fqdn": "example.com",
"organizational_unit": "string"
"domain_workgroup": "string",
"name": "CIFS1"
"comment": "string",
"dns": {
"domains": [
"example.com",
"example2.example3.com"
"servers": [
"10.224.65.20",
"2001:db08:a0b:12f0::1"
"fc_interfaces": [
"data_protocol": "string",
"name": "lif1",
"fcp": {
"ip_interfaces": [
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"services": [
"data_nfs"
"subnet": {
"name": "subnet1",
"ipspace": {
"name": "exchange",
"iscsi": {
"language": "c.utf_8",
"ldap": {
"ad_domain": "string",
"base_dn": "string",
"bind_dn": "string",
"servers": [
"string"
"max_volumes": "string",
"name": "svm1",
"nfs": {
"nis": {
"domain": "string",
"servers": [
"string"
"nsswitch": {
"group": [
"string"
"hosts": [
"string"
"namemap": [
"string"
"netgroup": [
"string"
"passwd": [
"string"
"number_of_volumes_in_recovery_queue": 0,
"nvme": {
"qos_adaptive_policy_group_template": {
"max_throughput_iops": 10000,
"max_throughput_mbps": 500,
"min_throughput_iops": 2000,
"min_throughput_mbps": 500,
"name": "performance",
"qos_policy": {
"s3": {
"certificate": {
"name": "string",
"default_unix_user": "string",
"default_win_user": "string",
"name": "s3-server-1"
"snapmirror": {
"protected_consistency_group_count": 0,
"protected_volumes_count": 0
"snapshot_policy": {
"name": "default",
"state": "running",
"storage": {
"allocated": 0,
"available": 0,
"used_percentage": 0
"subtype": "string",
"total_volume_size_in_recovery_queue": 0,
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
262188 |
Field "top_metric" was specified twice (to "iops.read" and "throughput.read"). |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
aggregates
_links |
available_size |
integer |
Space available, in bytes. |
name |
string |
snaplock_type |
string |
SnapLock type. |
state |
string |
Aggregate state. |
type |
string |
Type of aggregate. |
uuid |
string |
event_log
is_enabled_on_new_file_extension_seen |
boolean |
Specifies whether to send an EMS when a new file extension is discovered. |
is_enabled_on_snapshot_copy_creation |
boolean |
Specifies whether to send an EMS when a Snapshot copy is created. |
arw_vserver
event_log |
certificate
_links |
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
ad_domain
default_site |
string |
The default site used by LIFs that do not have a site membership. |
fqdn |
string |
The fully qualified domain name of the Windows Active Directory to which this CIFS server belongs. A CIFS server appears as a member of Windows server object in the Active Directory store. |
organizational_unit |
string |
Specifies the organizational unit within the Active Directory domain to associate with the CIFS server. |
cifs
_links |
ad_domain |
allowed |
boolean |
If this is set to true, an SVM administrator can manage the CIFS service. If it is false, only the cluster administrator can manage the service. |
domain_workgroup |
string |
The NetBIOS name of the domain or workgroup associated with the CIFS server. |
enabled |
boolean |
If allowed, setting to true enables the CIFS service. |
name |
string |
The NetBIOS name of the CIFS server. |
dns
_links |
domains |
array[string] |
A list of DNS domains. Domain names have the following requirements:
servers |
array[string] |
The list of IP addresses of the DNS servers. Addresses can be either IPv4 or IPv6 addresses. |
node
The node on which the FC port is located.
name |
string |
The name of the node on which the FC port is located. |
fc_port_reference
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network.
_links |
name |
string |
The name of the FC port. |
node |
The node on which the FC port is located. |
uuid |
string |
The unique identifier of the FC port. |
location
The location of the Fibre Channel interface is defined by the location of its port.
port |
An FC port is the physical port of an FC adapter on a cluster node that can be connected to an FC network. |
fc_interface_svm
_links |
data_protocol |
string |
The data protocol for which the Fibre Channel interface is configured. |
name |
string |
The name of the Fibre Channel interface. |
uuid |
string |
The unique identifier of the Fibre Channel interface. |
fcp
_links |
allowed |
boolean |
If this is set to true, an SVM administrator can manage the FCP service. If it is false, only the cluster administrator can manage the service. |
enabled |
boolean |
If allowed, setting to true enables the FCP service. |
ip
IP information
address |
string |
IPv4 or IPv6 address |
broadcast_domain
Broadcast domain UUID along with a readable name.
_links |
name |
string |
Name of the broadcast domain, scoped to its IPspace |
uuid |
string |
Broadcast domain UUID |
home_node
_links |
name |
string |
uuid |
string |
location
Home_node is optional.
broadcast_domain |
Broadcast domain UUID along with a readable name. |
home_node |
ip_subnet_reference
A named subnet. Either UUID or name can be supplied on input.
_links |
name |
string |
The name of the subnet. If only the name is provided, the IPspace scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the subnet. |
ip_interface_svm
Interface parameters. Name and home_node are optional.
_links |
ip |
IP information |
name |
string |
The name of the interface (optional). |
services |
array[string] |
The services associated with the interface. |
subnet |
A named subnet. Either UUID or name can be supplied on input. |
uuid |
string |
The UUID that uniquely identifies the interface. |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
iscsi
_links |
allowed |
boolean |
If this is set to true, an SVM administrator can manage the iSCSI service. If it is false, only the cluster administrator can manage the service. |
enabled |
boolean |
If allowed, setting to true enables the ISCSI service. |
ldap
ad_domain |
string |
This parameter specifies the name of the Active Directory domain
used to discover LDAP servers for use by this client.
This is mutually exclusive with |
base_dn |
string |
Specifies the default base DN for all searches. |
bind_dn |
string |
Specifies the user that binds to the LDAP servers. SVM API supports anonymous binding. For Simple and SASL LDAP binding, use the LDAP API endpoint. |
enabled |
boolean |
Enable LDAP? Setting to true creates a configuration if not already created. |
restrict_discovery_to_site |
boolean |
Specifies whether or not LDAP server discovery is restricted to site-scope. |
servers |
array[string] |
ndmp
allowed |
boolean |
If this is set to true, an SVM administrator can manage the NDMP service. If it is false, only the cluster administrator can manage the service. |
nfs
_links |
allowed |
boolean |
If this is set to true, an SVM administrator can manage the NFS service. If it is false, only the cluster administrator can manage the service. |
enabled |
boolean |
If allowed, setting to true enables the NFS service. |
nis
_links |
domain |
string |
The NIS domain to which this configuration belongs. |
enabled |
boolean |
Enable NIS? Setting to true creates a configuration if not already created. |
servers |
array[string] |
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration. |
nsswitch
group |
array[string] |
Group sources |
hosts |
array[string] |
Host sources |
namemap |
array[string] |
NameMap sources |
netgroup |
array[string] |
NetGroup sources |
passwd |
array[string] |
Password sources |
nvme
_links |
allowed |
boolean |
If this is set to true, an SVM administrator can manage the NVMe service. If it is false, only the cluster administrator can manage the service. |
enabled |
boolean |
If allowed, setting to true enables the NVMe service. |
_links |
max_throughput_iops |
integer |
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
max_throughput_mbps |
integer |
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_iops |
integer |
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. |
min_throughput_mbps |
integer |
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
qos_policy
_links |
integer |
integer |
integer |
integer |
name |
string |
uuid |
string |
ip_info
IP information
address |
string |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
network_route_for_svm
destination |
IP information |
gateway |
string |
The IP address of the gateway router leading to the destination. |
certificate
Specifies the certificate that will be used for creating HTTPS connections to the S3 server.
_links |
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
s3
_links |
certificate |
Specifies the certificate that will be used for creating HTTPS connections to the S3 server. |
default_unix_user |
string |
Specifies the default UNIX user for NAS Access. |
default_win_user |
string |
Specifies the default Windows user for NAS Access. |
enabled |
boolean |
Specifies whether or not to enable S3. Setting this value to true creates a service if one is not yet created. |
is_http_enabled |
boolean |
Specifies whether HTTP is enabled on the S3 server. By default, HTTP is disabled on the S3 server. |
is_https_enabled |
boolean |
Specifies whether HTTPS is enabled on the S3 server. By default, HTTPS is enabled on the S3 server. |
name |
string |
Specifies the name of the S3 server. A server name length can range from 1 to 253 characters and can only contain the following combination of characters 0-9, A-Z, a-z, ".", and "-". |
port |
integer |
Specifies the HTTP listener port for the S3 server. By default, HTTP is enabled on port 80. |
secure_port |
integer |
Specifies the HTTPS listener port for the S3 server. By default, HTTPS is enabled on port 443. |
snapmirror
is_protected |
boolean |
Specifies whether the SVM is a SnapMirror source SVM, using SnapMirror to protect its data. |
protected_consistency_group_count |
integer |
Specifies the number of SVM DR protected consistency groups in the SVM. |
protected_volumes_count |
integer |
Specifies the number of SVM DR protected volumes in the SVM. |
snapshot_policy
_links |
name |
string |
uuid |
string |
storage
allocated |
integer |
Total size of the volumes in SVM, in bytes. |
available |
integer |
Currently available storage capacity in SVM, in bytes. |
limit |
integer |
Maximum storage permitted on a single SVM, in bytes. |
limit_threshold_alert |
integer |
Indicates at what percentage of storage capacity an alert message is sent. The default value is 90. |
limit_threshold_exceeded |
boolean |
Indicates whether the total storage capacity exceeds the alert percentage. |
used_percentage |
integer |
The percentage of storage capacity used. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
