Manage application logs
Log events from standalone applications onto the ONTAP system using POST requests, encapsulating them as EMS events. These endpoints are essential for tracking application behavior and optionally generating AutoSupports based on event severity.
Overview
A POST request allows a standalone application to log its events on the ONTAP system as EMS events and optionally generate AutoSupports. This event information is encapsulated in an app.log.x event, or callhome.client.app.x event in case AutoSupport generation is required, based on the event's severity.
This API only supports POST. Generated events can be retrieved using the /api/support/ems/events API. |
Creating a new app.log.* event
The following example generates an app.log.error event.
# The API:
POST /api/support/ems/application-logs
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/application-logs" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "{ \"computer_name\": \"W12-R2-DC\", \"event_source\": \"SnapCenter Software\", \"app_version\": \"3.0.0.2373\", \"event_id\": 10001, \"category\": \"error\", \"event_description\": \"Clone split job failed\", \"severity\": \"error\", \"autosupport_required\": false}"
# The response:
201 CREATED
Retrieving a list of events generated by this API
The following example retrieves all app.log.* events.
# The API:
GET /api/support/ems/events
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/events?message.name=app.log.*" -H "accept: application/hal+json"
# The response:
200 OK
"records": [
"node": {
"name": "node1",
"uuid": "d96d5d8d-118a-11ec-aad8-005056bb974c",
"href": "/api/cluster/nodes/d96d5d8d-118a-11ec-aad8-005056bb974c"
"index": 7865,
"time": "2021-09-17T09:36:28-04:00",
"message": {
"severity": "emergency",
"name": "app.log.emerg"
"log_message": "app.log.emerg: iMac: iPad ipad3: (10001) handheld: TestLine1",
"href": "/api/support/ems/events/node1/7865"
"num_records": 1,
"href": "/api/support/ems/events?message.name=app.log.*"
