Manage disks
Retrieve information about all storage disks in the cluster to monitor and manage disk resources effectively. Use these endpoints to access detailed attributes and operational status for disks across your environment.
Retrieving storage disk information
The storage disk GET API retrieves all of the disks in the cluster.
1) Retrieve a list of disks from the cluster.
The following example shows the response with a list of disks in the cluster:
# The API:
/api/storage/disks
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/disks" -H "accept: application/hal+json"
# The response:
"records": [
"name": "1.24.4",
"href": "/api/storage/disks/1.24.4"
"name": "1.24.3",
"href": "/api/storage/disks/1.24.3"
"name": "1.24.5",
"href": "/api/storage/disks/1.24.5"
"name": "1.24.0",
"href": "/api/storage/disks/1.24.0"
"name": "1.24.2",
"href": "/api/storage/disks/1.24.2"
"name": "1.24.1",
"href": "/api/storage/disks/1.24.1"
"num_records": 6,
"href": "/api/storage/disks"
2) Retrieve a specific disk from the cluster.
The following example shows the response of the requested disk. If there is no disk with the requested name, an error is returned:
# The API:
/api/storage/disks/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/disks/1.24.3" -H "accept: application/hal+json"
# The response:
"name": "1.24.3",
"uid": "50000394:0808AA88:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000",
"serial_number": "EC47PC5021SW",
"model": "X421_FAL12450A10",
"vendor": "NETAPP",
"firmware_version": "NA02",
"usable_size": 438304768000,
"rpm": 10000,
"type": "sas",
"effective_type": "sas",
"class": "performance",
"container_type": "aggregate",
"pool": "pool0",
"state": "present",
"node": {
"uuid": "3a89ed49-8c6d-11e8-93bc-00a0985a64b6",
"name": "node-2",
"href": "/api/cluster/nodes/3a89ed49-8c6d-11e8-93bc-00a0985a64b6"
"home_node": {
"name": "node-2",
"aggregates": [
"uuid": "3fd9c345-ba91-4949-a7b1-6e2b898d74e3",
"name": "node_2_SAS_1",
"href": "/api/storage/aggregates/3fd9c345-ba91-4949-a7b1-6e2b898d74e3"
"shelf": {
"uid": "10318311901725526608",
"href": "/api/storage/shelves/10318311901725526608"
"local": true,
"paths": [
"initiator": "3a",
"port_name": "B",
"port_type": "sas",
"wwnn": "5000cca02f0e6768",
"wwpn": "5000cca02f0e676a",
"node": {
"name": "vsim3",
"uuid": "3f7fa09a-5c56-11ec-b366-005056bbbb3f",
"href": "/api/cluster/nodes/3f7fa09a-5c56-11ec-b366-005056bbbb3f"
"initiator": "3d",
"port_name": "A",
"port_type": "sas",
"wwpn": "5000cca02f0e6769",
"node": {
"name": "vsim4",
"uuid": "4f7fa09a-5c56-11ec-b366-005056bbbb3f",
"href": "/api/cluster/nodes/4f7fa09a-5c56-11ec-b366-005056bbbb3f"
"initiator": "3d",
"port_name": "A",
"port_type": "sas",
"node": {
"name": "vsim3",
"initiator": "3a",
"port_name": "B",
"port_type": "sas",
"node": {
"name": "vsim4",
"outage": {
"persistently_failed": true,
"reason": {
"message": "Failed disk. Reason: \"admin failed\".",
"code": "721081"
"bay": 3,
"error": [
"reason": {
"message": "\"The node is configured with All-Flash Optimized personality and this disk is not an SSD. The disk needs to be removed from the system.\"",
"code": "721082"
"type": "notallflashdisk"
"bytes_per_sector": 512,
"sector_count": 1172123568,
"right_size_sector_count": 5579776,
"physical_size": 438804988000,
"stats": {
"average_latency": 6,
"throughput": 1957888,
"iops_total": 12854,
"path_error_count": 0,
"power_on_hours": 11797
3) Retrieving a specific disk from the hypervisor
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/disks/NET-3.2" -H "accept: application/hal+json"
# The response:
"name": "NET-3.2",
"uid": "32343637:65386464:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000",
"serial_number": "3234363765386464",
"model": "PHA-DISK",
"vendor": "NETAPP",
"firmware_version": "0001",
"type": "vmdisk",
"class": "virtual",
"container_type": "mediator",
"pool": "pool0",
"node": {
"uuid": "f4cb78ba-5841-11ec-80c4-916f62b4cd44",
"name": "aws-43905099-44129379-awsha-vm1",
"href": "/api/cluster/nodes/f4cb78ba-5841-11ec-80c4-916f62b4cd44"
"home_node": {
"local": true,
"paths": [
"initiator": "0f",
"port_name": "A",
"port_type": "sas",
"wwnn": "53059d50444f5476",
"wwpn": "53059d50444f5476",
"vmdisk_hypervisor_file_name": "LUN 4.0",
"node": {
"initiator": "0f",
"port_name": "A",
"port_type": "sas",
"vmdisk_hypervisor_file_name": "LUN 2.0",
"node": {
"outage": {
"persistently_failed": false,
"reason": {
"message": "Failed disk. Reason: \"\".",
"code": "721081"
"self_encrypting": false,
"fips_certified": false,
"sector_count": 204808,
"physical_size": 204808,
"stats": {
"average_latency": 2157188883,
"throughput": 4096,
"iops_total": 1,
"power_on_hours": 0
"href": "/api/storage/disks/NET-3.2"
Modifying storage disk
The storage disk PATCH API modifies disk ownership, unfails a disk, or updates encrypting drive authentication keys (AKs) in the cluster. The storage disk API currently supports patching one attribute at a time.
Updating the disk ownership for a specified disk
1. When the disk is not assigned
When the disk is a spare (or unowned) disk and node name is specified, the PATCH operation assigns the disk to the specified node. Optionally, pool name can also be specified along with node name. Accepted pool names are: pool0, pool1.
2. When the disk is already assigned
When the disk is already assigned (already has a owner), and a new node is specified, the PATCH operation changes the ownership to the new node. Optionally, pool name can also be specified along with node name. Accepted pool names are: pool0, pool1.
Removing the disk ownership for a specified disk
When the disk is already assigned, and node name is specified as null (no-quotes), the PATCH operation removes the owner.
1. Update the disk ownership for an unowned disk
# The API:
/api/storage/disks
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/disks?name=<disk-name>" -H "accept: application/hal+json" -H "Content-Type: application/hal+json" -d '{"node": {"name": "node-name"}}'
# The response:
2. Update the disk ownership for an already owned disk
# The API:
/api/storage/disks
# The call:
# The response:
3. Update the disk pool for a disk (can be either owned or unowned).
# The API:
/api/storage/disks
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/disks?name=<disk-name>" -H "accept: application/hal+json" -H "Content-Type: application/hal+json" -d '{"node": {"name": "node-name"}, "pool": "pool0"}'
# The response:
4. Rekey the data authentication key (AK) of all encrypting drives to an authentication key (AK) selected automatically by the system
# The API:
/api/storage/disks
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/disks?name=*&encryption_operation=rekey_data_auto_id" -H "accept: application/hal+json" -H "Content-Type: application/hal+json"
# The response contains the number of disks attempted.
"num_records": 32
5. Cryptographically sanitize a spare or broken disk
# The API:
/api/storage/disks
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/disks?name=<disk-name>&encryption_operation=sanitize_disk" -H "accept: application/hal+json" -H "Content-Type: application/hal+json"
"num_records": 1
6. Unfailing a disk to a spare.
# The API:
/api/storage/disks
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/disks?name=<disk-name>" -d '{"state": "spare"}' -H "accept: application/hal+json" -H "Content-Type: application/hal+json"
# The response:
7. Unfailing a disk and attempting to reassimilate filesystem labels.
If unable or unnecessary to reassimilate filesystem labels, the disk will be set as spare.
# The API:
/api/storage/disks
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/disks?name=<disk-name>" -d '{"state": "present"}' -H "accept: application/hal+json" -H "Content-Type: application/hal+json"
# The response:
