REST API reference
Manage keystores
Manage keystore configurations, including the type and status of key managers, to ensure security settings align with your storage virtual machine (SVM) requirements. Use these endpoints to retrieve, update, and delete specific keystore details based on activity status.
Overview
A keystore describes a key-manager configuration, specifically the type of key-manager and whether the configuration is currently enabled for the configured SVM.
Retrieving information for all configured key managers
The following example shows how to retrieve information about all configured key managers.
# The API:
GET /api/security/key-stores
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/key-stores?fields=*' -H 'accept: application/hal+json'
# The response:
"records": [
    "uuid": "33421d82-0a8d-11ec-ae88-005056bb5955",
    "configuration": {
      "name": "default",
          "href": "/api/security/azure-key-vaults/33421d82-0a8d-11ec-ae88-005056bb5955"
    "enabled": true,
    "type": "akv",
    "location": "external",
        "href": "/api/security/key-stores/33421d82-0a8d-11ec-ae88-005056bb5955"
    "uuid": "46a0b20a-0a8d-11ec-ae88-005056bb5955",
    "configuration": {
      "name": "default",
          "href": "/api/security/key-managers/46a0b20a-0a8d-11ec-ae88-005056bb5955"
    "enabled": false,
    "type": "kmip",
        "href": "/api/security/key-stores/46a0b20a-0a8d-11ec-ae88-005056bb5955"
"num_records": 2,
    "href": "/api/security/key-stores?fields=*"
Retrieving a specific keystore by its UUID
The following example shows how to retrieve information about a specific keystore.
# The API:
GET /api/security/key-stores/{uuid}
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/key-stores/33421d82-0a8d-11ec-ae88-005056bb5955?fields=*' -H 'accept: application/hal+json'
# The response:
"configuration": {
  "name": "default",
"enabled": true,
"type": "akv",
    "href": "/api/security/key-stores/33421d82-0a8d-11ec-ae88-005056bb5955?fields=*"
Enabling a specific keystore configuration
The following example shows how to enable a specific keystore configuration.
# The API:
PATCH /api/security/key-stores/{uuid}
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/security/key-stores/33421d82-0a8d-11ec-ae88-005056bb5955' -H 'accept: application/hal+json' -d "{ \"enabled\": true }"
Deleting a specific keystore configuration
The following example shows how to delete a specific keystore configuration. Only an inactive configuration can be deleted.
# The API:
DELETE /api/security/key-stores/{uuid}
# The call:
curl -X DELETE 'https://<mgmt-ip>/api/security/key-stores/33421d82-0a8d-11ec-ae88-005056bb5955' -H 'accept: application/hal+json'
