REST API reference
Manage local group members
Manage local group members to display and modify the membership of local groups within an SVM. Use these endpoints to add or remove local users, Active Directory users, and groups to ensure accurate group compositions.
Overview
You can use this API to display local group members and to add or delete local users, Active Directory users and/or Active Directory groups to a local group of an SVM.
Retrieving the members of a specific local group
# The API:
/api/protocols/cifs/local-groups/{svm.uuid}/{local_cifs_group.sid}/members
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/cifs/local-groups/2ebec9c7-28be-11eb-95f4-0050568ed0a2/S-1-5-21-256008430-3394229847-3930036330-1257/members" -H "accept: application/json"
# The response:
"records": [
    "name": "CIFS_SERVER1\\user1"
    "name": "CIFS_SERVER1\\user2"
"num_records": 2
Adding members to a local group
The local group members POST endpoint adds local users, Active Directory users and/or Active Directory groups to the specified local group and the SVM.
Adding local users to a group
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/cifs/local-groups/179d3c85-7053-11e8-b9b8-005056b41bd1/S-1-5-21-256008430-3394229847-3930036330-1001/members" -H "accept: application/json" -H "Content-Type: application/json" -d '{ "records": [ { "name": "user1" }, { "name": "user2"} ] }'
Deleting local users from the local group of a specific SVM
Example
Delete the local users 'user1' and 'user2' from the specified local group
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/cifs/local-groups/179d3c85-7053-11e8-b9b8-005056b41bd1/S-1-5-21-256008430-3394229847-3930036330-1001/members" -H "accept: application/json" -d '{ "records": [ { "name": "user1"}, { "name": "user2"} ] }'
