REST API reference
Manage netgroup cache settings
Retrieve and manage netgroup cache settings to optimize name service queries within your ONTAP environment. Use these endpoints to access current settings and modify cache configurations as needed for specific storage virtual machines (SVMs).
Overview
This API is used to retrieve and manage netgroups cache settings.
Retrieving a netgroup cache setting
The following example shows how to use the cache netgroup settings GET endpoint to retrieve netgroup cache settings.
# The API:
GET /api/name-services/cache/netgroup/settings
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/cache/netgroup/settings?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
    "svm": {
      "uuid": "8a1a8730-2036-11ec-8457-005056bbcfdb",
      "name": "vs43"
    "enabled": true,
    "negative_cache_enabled_byhost": true,
    "ttl_byhost": "P1D",
    "negative_ttl_byhost": "PT30M",
    "ttl_for_members": "PT30M"
    "svm": {
      "uuid": "dc458b2f-2035-11ec-bfe2-005056bb6bef",
      "name": "vs34"
    "enabled": true,
    "ttl_byhost": "PT2H",
"num_records": 2
Retrieving a netgroup cache setting for a given SVM
The following example shows how to use the cache netgroup settings GET endpoint to retrieve netgroup cache settings for a given SVM.
# The API:
GET /api/name-services/cache/netgroup/settings/{svm.uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/cache/netgroup/settings/dc458b2f-2035-11ec-bfe2-005056bb6bef" -H "accept: application/hal+json"
# The response:
"svm": {
  "name": "vs34"
"enabled": true,
Updating a netgroup cache setting
The following example shows how to use the cache netgroup settings PATCH endpoint to update netgroup cache settings.
# The API:
PATCH /api/name-services/cache/netgroup/settings/{svm.uuid}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/cache/netgroup/settings/02c9e252-41be-11e9-81d5-00a0986138f9" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"ttl_byhost\": \"PT2H\", \"negative_ttl_byhost\": \"PT2M\" }"
