REST API reference
Manage NFS services
Manage NFS services to configure, update, and monitor network file sharing capabilities within your storage virtual machine (SVM). Use these endpoints to retrieve and set mount permissions, create and modify NFS configurations, and ensure optimal access for your environment.
Retrieving an NFS configuration
# The API:
GET /api/protocols/nfs/services
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/nfs/services"
Retrieving the mount permissions for a specified volume for a given IP address.
# The API:
# The call:
curl -X GET curl -X GET "https://<mgmt-ip>/api/protocols/nfs/services?protocol_access_rules.volume=testvol12&protocol_access_rules.client_ip=1.2.3.4&protocol_access_rules.auth_type=sys&svm.uuid=525928e9-9f84-11eb-a89f-005056bb70a8&fields=*&return_timeout=15&return_records=true"
Returns the protocol_access_rules structure and provides access permissions for each protocol.
"protocol_access_rules": {
  "nfs3_access_type": "read_write",
  "nfs4_access_type": "read",
  "cifs_access_type": "read_write"
Creating an NFS configuration for an SVM
# The API:
POST /api/protocols/nfs/services
# The call:
curl  -d "@test_nfs_post.txt" -X POST "https://<mgmt-ip>/api/protocols/nfs/services"
test_nfs_post.txt(body):
"svm": {
"protocol": {
  "v4_id_domain": "nfs-nsr-w01.rtp.netapp.com"
"vstorage_enabled": "true"
Updating an NFS configuration for an SVM
# The API:
PATCH /api/protocols/nfs/services/{svm.uuid}
# The call:
curl -d "@test_nfs_patch.txt" -X PATCH "https://<mgmt-ip>/api/protocols/nfs/services/4a415601-548c-11e8-a21d-0050568bcbc9"
test_nfs_patch.txt(body):
"protocol": {
"vstorage_enabled": "false"
Deleting an NFS configuration for an SVM
# The API:
DELETE /api/protocols/nfs/services/{svm.uuid}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/nfs/services/4a415601-548c-11e8-a21d-0050568bcbc9"
Performance monitoring
Performance of the SVM can be monitored by the metric.* and statistics.* properties. These show the performance of the SVM in terms of IOPS, latency and throughput. The metric.* properties denote an average whereas statistics.* properties denote a real-time monotonically increasing value aggregated across all nodes.
