REST API reference
Manage NIS configuration
Retrieve and manage NIS server configurations to authenticate users and client computers within your ONTAP environment. Use these endpoints to configure NIS domain names and server information effectively.
Overview
NIS servers are used to authenticate user and client computers. NIS domain name and NIS server information is required to configure NIS. This API retrieves and manages NIS server configurations.
Retrieving cluster NIS information
The cluster NIS GET request retrieves the NIS configuration of the cluster.
The following example shows how a GET request is used to retrieve the cluster NIS configuration:
# The API:
/security/authentication/cluster/nis
# The call:
curl -X GET "https://<mgmt-ip>/api/security/authentication/cluster/nis" -H "accept: application/hal+json"
# The response:
"domain": "domainA.example.com",
"servers": [
  "10.10.10.10",
  "example.com"
"bound_servers": [
  "10.10.10.10"
Creating the cluster NIS configuration
The cluster NIS POST request creates a NIS configuration for the cluster.
The following example shows how a POST request is used to create a cluster NIS configuration:
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/security/authentication/cluster/nis" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"domain\": \"domainA.example.com\", \"servers\": [ \"10.10.10.10\",\"example.com\" ]}"
Updating the cluster NIS configuration
The cluster NIS PATCH request updates the NIS configuration of the cluster.
The following example shows how to update the domain:
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/authentication/cluster/nis" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"domain\": \"domainC.example.com\", \"servers\": [ \"13.13.13.13\" ]}"
The following example shows how to update the server:
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/authentication/cluster/nis" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"servers\": [ \"14.14.14.14\" ]}"
Deleting the cluster NIS configuration
The cluster NIS DELETE request deletes the NIS configuration of the cluster.
The following example shows how a DELETE request is used to delete the cluster NIS configuration:
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/security/authentication/cluster/nis" -H "accept: application/hal+json"
