Manage SVM peer permissions
Manage SVM peer permissions to streamline intercluster SVM peer relationship creation without requiring explicit acceptance for incoming requests. These endpoints simplify permission handling by allowing wildcard SVM names to apply permissions across all local SVMs.
Managing SVM peer permissions
A cluster administrator can provide permissions for use during intercluster SVM peer relationship creation. Once this permission exists for a local SVM and peer cluster combination on a local cluster, no explicit SVM peer accept (or REST PATCH) API is required for any incoming SVM peer relationship creation requests from a remote cluster for that local SVM. Peer relationship directly changes the state to peered on both clusters. Use an SVM name as "*" to create permissions that apply to all local SVMs.
SVM peer permission APIs
The following APIs are used to manage SVM peer permissions:
GET /api/svm/peer-permissions
POST /api/svm/peer-permissions
GET /api/svm/peer-permissions/{cluster_peer.uuid}/{svm.uuid}
PATCH /api/svm/peer-permissions/{cluster_peer.uuid}/{svm.uuid}
DELETE /api/svm/peer-permissions/{cluster_peer.uuid}/{svm.uuid}
