REST API reference
Manage UNIX user cache settings
Use the UNIX user cache settings endpoints to retrieve and manage cache configurations for UNIX users within your system. These endpoints help optimize access by controlling cache duration and propagation for specific Storage Virtual Machines (SVMs).
Overview
This API is used to retrieve and manage unix-user settings.
Retrieving unix-user cache settings
The following example shows how to use the cache unix-user settings GET endpoint to retrieve unix-user cache settings.
# The API:
GET /api/name-services/cache/unix-user/settings
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/cache/unix-user/settings?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
    "svm": {
      "uuid": "8a1a8730-2036-11ec-8457-005056bbcfdb",
      "name": "vs43"
    "enabled": true,
    "negative_cache_enabled": true,
    "ttl": "P1D",
    "negative_ttl": "PT1M",
    "propagation_enabled": true
    "svm": {
      "uuid": "dc458b2f-2035-11ec-bfe2-005056bb6bef",
      "name": "vs34"
    "enabled": true,
    "ttl": "P1D",
"num_records": 2
Retrieving a unix-user cache setting for a given SVM
The following example shows how to use the cache unix-user settings GET endpoint to retrieve unix-user cache settings for a given SVM.
# The API:
GET /api/name-services/cache/unix-user/settings/{svm.uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/cache/unix-user/settings/dc458b2f-2035-11ec-bfe2-005056bb6bef" -H "accept: application/hal+json"
# The response:
"svm": {
  "name": "vs34"
"enabled": true,
"ttl": "P1D",
Updating a unix-user setting
The following example shows how to use the cache unix-user settings PATCH endpoint to update unix-user cache settings.
# The API:
PATCH /api/name-services/cache/unix-user/settings/{svm.uuid}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/cache/unix-user/settings/02c9e252-41be-11e9-81d5-00a0986138f9" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"ttl\": \"PT2H\", \"negative_ttl\": \"PT2M\" }"
