Manage volume efficiency policies
Volume efficiency policy endpoints manage the application and attributes of efficiency policies on volumes. Use these operations to create, update, retrieve, and delete policies, optimizing data storage and performance in your environment.
Overview
Volume efficiency policies specify information about efficiency policies that are applied to the volume.
Volume efficiency policy APIs
The following APIs are used to perform operations related to volume efficiency policy information:
– POST /api/storage/volume-efficiency-policies
– GET /api/storage/volume-efficiency-policies
– GET /api/storage/volume-efficiency-policies/{uuid}
– PATCH /api/storage/volume-efficiency-policies/{uuid}
– DELETE /api/storage/volume-efficiency-policies/{uuid}
Creating a volume efficiency policy
The POST operation is used to create a volume efficiency policy with the specified attributes.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/volume-efficiency-policies" -H "accept: application/hal+json" -d '{"name": "new_policy", "type": "scheduled", "schedule": { "name": "daily" }, "duration": "2", "qos_policy": "best_effort", "enabled": "true", "comment": "schedule-policy", "svm": { "name": "vs1"}}'
# The response:
HTTP/1.1 201 Created
Date: Tue, 12 Mar 2019 21:20:24 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Location: /api/storage/volume-efficiency-policies/a69d8173-450c-11e9-aa44-005056bbc848
Content-Length: 369
Content-Type: application/json
"num_records": 1,
"records": [
"uuid": "a69d8173-450c-11e9-aa44-005056bbc848",
"svm": {
"name": "vs1"
"schedule":{
"name": "daily"
"duration": "2",
"enabled": "true",
Retrieving volume efficiency policy attributes
The GET operation is used to retrieve volume efficiency policy attributes.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/volume-efficiency-policies" -H "accept: application/hal+json"
# The response:
HTTP/1.1 200 OK
Date: Tue, 12 Mar 2019 21:17:17 GMT
Content-Length: 686
"records": [
"uuid": "3c112527-2fe8-11e9-b55e-005056bbf1c8",
"name": "default",
"href": "/api/storage/volume-efficiency-policies/3c112527-2fe8-11e9-b55e-005056bbf1c8"
"uuid": "3c1c1656-2fe8-11e9-b55e-005056bbf1c8",
"name": "default-1weekly",
"href": "/api/storage/volume-efficiency-policies/3c1c1656-2fe8-11e9-b55e-005056bbf1c8"
"uuid": "3c228b82-2fe8-11e9-b55e-005056bbf1c8",
"name": "none",
"href": "/api/storage/volume-efficiency-policies/3c228b82-2fe8-11e9-b55e-005056bbf1c8"
"num_records": 3,
"href": "/api/storage/volume-efficiency-policies/"
Retrieving the attributes of a specific volume efficiency policy
The GET operation is used to retrieve the attributes of a specific volume efficiency policy.
The API:
The call:
The response:
HTTP/1.1 200 OK Date: Tue, 12 Mar 2019 21:24:48 GMT Server: libzapid-httpd X-Content-Type-Options: nosniff Cache-Control: no-cache,no-store,must-revalidate Content-Length: 381 Content-Type: application/json { "uuid": "3c112527-2fe8-11e9-b55e-005056bbf1c8", "name": "new_policy", "type": "scheduled", "schedule": { "name": "daily" } "duration": "2", "qos_policy": "best_effort", "enabled": "true", "comment": "schedule-policy", "svm": { "name": "vs1" } "_links": { "self": { "href": "/api/storage/volume-efficiency-policies/3c112527-2fe8-11e9-b55e-005056bbf1c8" } } }
### Updating a volume efficiency policy The PATCH operation is used to update the specific attributes of a volume efficiency policy.
The API:
The call:
curl -X PATCH "https://
The response:
HTTP/1.1 200 OK Date: Tue, 12 Mar 2019 21:27:04 GMT Server: libzapid-httpd X-Content-Type-Options: nosniff Cache-Control: no-cache,no-store,must-revalidate Content-Length: 3 Content-Type: application/json
### Deleting a volume efficiency policy The DELETE operation is used to delete a volume efficiency policy.
The API:
The call:
curl -X DELETE "https://
The response:
HTTP/1.1 200 OK Date: Tue, 12 Mar 2019 21:19:04 GMT Server: libzapid-httpd X-Content-Type-Options: nosniff Cache-Control: no-cache,no-store,must-revalidate Content-Length: 3 Content-Type: application/json
