Manage Vscan On-Access policies
Manage Vscan On-Access policy configurations to actively scan file objects for viruses when accessed over SMB. Retrieve, create, update, and delete policy configurations to control the scope and status of scanning operations on file objects within a Storage Virtual Machine (SVM).
Overview
Use Vscan On-Access scanning to actively scan file objects for viruses when clients access files over SMB. To control which file operations trigger a vscan, use Vscan File-Operations Profile (vscan-fileop-profile) option in the CIFS share. The Vscan On-Access policy configuration defines the scope and status of On-Access scanning on file objects. Use this API to retrieve and manage Vscan On-Access policy configurations and Vscan On-Access policy statuses for the SVM.
Retrieving all fields for all policies of an SVM
# The API:
/api/protocols/vscan/{svm.uuid}/on-access-policies/
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/{svm.uuid}/on-access-policies?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
"svm": {
"uuid": "179d3c85-7053-11e8-b9b8-005056b41bd1",
"name": "vs1",
"href": "/api/svm/svms/179d3c85-7053-11e8-b9b8-005056b41bd1"
"name": "default_CIFS",
"enabled": true,
"mandatory": true,
"scope": {
"max_file_size": 2147483648,
"include_extensions": [
"scan_without_extension": true,
"scan_readonly_volumes": false,
"only_execute_access": false
"href": "/api/protocols/vscan/179d3c85-7053-11e8-b9b8-005056b41bd1/on-access-policies/default_CIFS"
"svm": {
"name": "vs1",
"name": "on-access-policy",
"enabled": false,
"mandatory": true,
"scope": {
"max_file_size": 3221225472,
"exclude_paths": [
"\\vol\\a b\\",
"\\vol\\a,b\\"
"mp*",
"tx*"
"exclude_extensions": [
"mp3",
"txt"
"only_execute_access": true
"href": "/api/protocols/vscan/179d3c85-7053-11e8-b9b8-005056b41bd1/on-access-policies/on-access-policy"
"num_records": 2,
"href": "/api/protocols/vscan/179d3c85-7053-11e8-b9b8-005056b41bd1/on-access-policies?fields=*"
Retrieving the specific On-Access policy associated with the specified SVM
# The API:
/api/protocols/vscan/{svm.uuid}/on-access-policies/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/179d3c85-7053-11e8-b9b8-005056b41bd1/on-access-policies/on-access-policy" -H "accept: application/json"
# The response:
"svm": {
"name": "vs1",
"enabled": true,
"mandatory": true,
"scope": {
"exclude_paths": [
"\\vol\\a b\\",
"\\vol\\a,b\\"
"mp*",
"tx*"
"mp3",
"txt"
"href": "/api/protocols/vscan/179d3c85-7053-11e8-b9b8-005056b41bd1/on-access-policies/task1"
Creating a Vscan On-Access policy
The Vscan On-Access policy POST endpoint creates an On-Access policy for the specified SVM. Set enabled to "true" to enable scanning on the created policy.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/vscan/86fbc414-f140-11e8-8e22-0050568e0945/on-access-policies?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"enabled\": false, \"mandatory\": true, \"name\": \"on-access-policy\", \"scope\": { \"exclude_extensions\": [ \"txt\", \"mp3\" ], \"exclude_paths\": [ \"\\\\dir1\\\\dir2\\\\ame\", \"\\\\vol\\\\a b\" ], \"include_extensions\": [ \"mp*\", \"txt\" ], \"max_file_size\": 3221225472, \"only_execute_access\": true, \"scan_readonly_volumes\": false, \"scan_without_extension\": true }}"
# The response:
"num_records": 1,
"records": [
"svm": {
"name": "vs1"
"enabled": false,
"mandatory": true,
"scope": {
"exclude_paths": [
"\\dir1\\dir2\\ame",
"\\vol\\a b"
"mp*",
"txt"
"txt",
"mp3"
Creating a Vscan On-Access policy where a number of optional fields are not specified
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/vscan/86fbc414-f140-11e8-8e22-0050568e0945/on-access-policies?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"enabled\": false, \"mandatory\": true, \"name\": \"on-access-policy\", \"scope\": { \"exclude_paths\": [ \"\\\\vol\\\\a b\", \"\\\\vol\\\\a,b\\\\\" ], \"max_file_size\": 1073741824, \"scan_without_extension\": true }}"
# The response:
"num_records": 1,
"records": [
"svm": {
"name": "vs1"
"enabled": false,
"mandatory": true,
"scope": {
"max_file_size": 1073741824,
"exclude_paths": [
"\\vol\\a b",
"\\vol\\a,b\\"
Updating a Vscan On-Access policy
The policy being modified is identified by the UUID of the SVM and the policy name.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/vscan/86fbc414-f140-11e8-8e22-0050568e0945/on-access-policies/on-access-policy" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "{ \"scope\": { \"include_extensions\": [ \"txt\" ], \"only_execute_access\": true, \"scan_readonly_volumes\": false, \"scan_without_extension\": true }}"
Deleting a Vscan On-Access policy
The policy to be deleted is identified by the UUID of the SVM and the policy name.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/vscan/86fbc414-f140-11e8-8e22-0050568e0945/on-access-policies/on-access-policy" -H "accept: application/hal+json"
