REST API reference
Update the local user information for a user and SVM
Updates local user information for a specific user and SVM, including renaming the user or setting their password. Use this endpoint to manage user credentials and identities within the system.
HTTP method and endpoint
PATCH /protocols/cifs/local-users/{svm.uuid}/{sid}
Introduced in
ONTAP 9.10
Usage notes
Updates local user information for the specified user and SVM. The PATCH endpoint is also used to rename a user and to set the password for the user.
  • vserver cifs users-and-groups local-user modify
  • vserver cifs users-and-groups local-user rename
  • vserver cifs users-and-groups local-user set-password
sid
string
path
True
Local user SID
svm.uuid
string
path
True
Request Body
Name Type Description
account_disabled
boolean
Indicates whether the user account is enabled or disabled.
description
string
Description for the local user.
full_name
string
User's full name.
membership
array[membership]
Specifies local groups of which this local user is a member.
name
string
Local user name. The maximum supported length of an user name is 20 characters.
password
string
Password for the local user.
sid
string
The security ID of the local user which uniquely identifies the user. The user SID is automatically generated in POST and it is retrieved using the GET method.
svm
svm
Example request
  "description": "This is local user.",
  "full_name": "user name",
  "membership": [
      "name": "SMB_SERVER01\\group",
      "sid": "S-1-5-21-256008430-3394229847-3930036330-1001"
  "name": "SMB_SERVER01\\user",
  "password": "string",
  "sid": "S-1-5-21-256008430-3394229847-3930036330-1001",
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
655661
The user name should not exceed 20 characters. Also full_name and description should not exceed 256 characters.
655668
The specified user name contains illegal characters.
655675
The local domain name specified in the user name does not exist.
655682
The user name cannot be blank.
655732
Failed to rename a user. The error code returned details the failure along with the reason for the failure. Take corrective actions as per the specified reason.
655733
The specified password does not meet the password complexity requirements.
655737
To rename an existing user, the local domain specified in name must match the local domain of the user to be renamed.
string
membership
name
string
Local group name. The maximum supported length of a group name is 256 characters.
sid
string
The security ID of the local group which uniquely identifies the group. The group SID is automatically generated in POST and it is retrieved using the GET method.
svm
name
string
uuid
string
local_cifs_user
account_disabled
boolean
description
string
full_name
string
User's full name.
membership
array[membership]
name
string
password
string
sid
string
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
