REST API reference
Update the S3 bucket lifecycle rule configuration
PATCH /protocols/s3/services/{svm.uuid}/buckets/{s3_bucket.uuid}/rules/{name}
Introduced In: 9.13
Updates the S3 bucket lifecycle rule configuration.
Important notes
  • The following fields can be modified for a bucket:
  • actions - Lifecycle Management actions associated with the rule.
  • enabled - Lifecycle Management rule is enabled or not..
  • object_age_days - Number of days since creation after which objects can be deleted.
  • object_expiry_date - Specific date from when objects can expire.
  • expired_object_delete_marker - Cleanup object delete markers.
  • new_non_current_versions - Number of latest non-current versions to be retained.
  • non_current_days - Number of days after which non-current versions can be deleted.
  • after_initiation_days - Number of days of initiation after which uploads can be aborted.
  • vserver object-store-server bucket lifecycle-management-rule modify
s3_bucket.uuid
string
path
True
The unique identifier of the bucket.
name
string
path
True
The name of the lifecycle management rule to be applied on the bucket.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
svm.uuid
string
path
True
  • Introduced in: 9.14
Request Body
Name Type Description
abort_incomplete_multipart_upload
Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags.
enabled
boolean
Specifies whether or not the associated rule is enabled.
expiration
expiration
Specifies a way to perform expiration action on filtered objects within a bucket.
non_current_version_expiration
Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
svm
svm
Specifies the name of the SVM where this bucket exists.
uuid
string
Specifies the unique identifier of the bucket.
Example request
  "expiration": {
    "object_expiry_date": "string"
  "svm": {
    "name": "svm1",
  "uuid": "414b29a1-3b26-11e9-bd58-0050568ea055"
Status: 200, Ok
num_records
integer
Number of records
records
array[s3_bucket_lifecycle_rule]
  "num_records": 1,
  "records": [
      "expiration": {
      "svm": {
        "name": "svm1",
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error code Message
92405861
"The specified SVM UUID or bucket UUID does not exist.";
92406114
"The Expiration action requires specifying either object_expiry_date, object_age_days or expired_object_delete_marker.";
92406115
"The NonCurrentVersionExpiration action requires either new_non_current_versions or non_current_days.";
92406116
"The AbortIncompleteMultipartUpload action requires after_initiation_days.";
92406117
"The Expiration action cannot have both an expiry date and an age.";
92406118
"Using Lifecycle Management rules requires an effective cluster version of 9.13.1 .";
92406119
"One or more object store buckets exist with Lifecycle Management rules. To list the buckets, run the vserver object-store-server bucket lifecycle-management-rule show command. To delete the buckets, use the vserver object-store-server bucket delete command.";
92406120
"The AbortIncompleteMultipartUpload action cannot be specified with tags.";
92406121
"Expired object delete marker cannot be specified with tags.";
92406122
"Expired object delete marker cannot be specified with object age days or expiry date.";
92406123
"Expiration is supported on object store volumes only, bucket on Vserver is not an object store volume.";
92406126
"Lifecycle Management rule for bucket in Vserver is invalid because specified tags contain one or more invalid characters. Valid characters for a tag are 0-9, A-Z, a-z, +, -, =, ., _, :, /, @.";
92406131
"Lifecycle Management rule for bucket in Vserver cannot be created because non_current_days must be specified when new_non_current_versions is specified.";
92406132
"Lifecycle Management rule "" for bucket "" in SVM "" requires "object_age_days" to be greater than zero."; //end row //start row
92406132 //end row //start row
"Lifecycle Management rule "" for bucket "" in SVM "" requires "new_non_current_versions" to be greater than zero."; //end row //start row
"Lifecycle Management rule "" for bucket "" in SVM "" requires "after_initiation_days" to be greater than zero."; //end row //start row
92406133 //end row //start row
"Lifecycle Management rule for bucket in Vserver is invalid. The object_expiry_date must be later than January 1, 1970."; //end row //start row
92406135 //end row //start row
"MetroCluster is configured on cluster. Object Expiration is not supported in a MetroCluster configuration."; //end row //start row
92406136 //end row //start row
"Lifecycle Management rule for bucket in Vserver is invalid. The object_expiry_date must be at midnight GMT."; //end row //start row
92406139 //end row //start row
"Lifecycle Management rule for bucket in Vserver with action is a stale entry. Contact technical support for assistance."; //end row //start row
92406140 //end row //start row
"Expired object delete marker must be enabled to create a Lifecycle Management rule."; //end row //start row
92406141 //end row //start row
"Lifecycle Management rule for bucket in Vserver with action cannot have expired_object_delete_marker disabled. To disable expired_object_delete_marker, run vserver object-store-server bucket lifecycle-management-rule delete"; //end row //start row
92406144 //end row //start row
"The "AbortIncompleteMultipartUpload" action cannot be specified with object size."; //end row //start row
92406150 //end row //start row
""expired_object_delete_marker" cannot be specified with "size_less_than"."; //end row
|Name |Type |Description
|href |string a|
[#_links] [.api-collapsible-fifth-title] _links [#abort_incomplete_multipart_upload] [.api-collapsible-fifth-title] abort_incomplete_multipart_upload
[cols=3*,options=header]
|after_initiation_days |integer a|Number of days of initiation after which uploads can be aborted.
[#expiration] [.api-collapsible-fifth-title] expiration
|expired_object_delete_marker |boolean a|Cleanup object delete markers.
|object_age_days |integer a|Number of days since creation after which objects can be deleted. This cannot be used along with object_expiry_date.
|object_expiry_date |string a|Specific date from when objects can expire. This cannot be used with object_age_days.
[#non_current_version_expiration] [.api-collapsible-fifth-title] non_current_version_expiration
|new_non_current_versions |integer a|Number of latest non-current versions to be retained.
|non_current_days |integer a|Number of days after which non-current versions can be deleted.
[#object_filter] [.api-collapsible-fifth-title] object_filter
Specifies a way to filter objects within a bucket.
|prefix |string a|A prefix that is matched against object-names within a bucket.
|size_greater_than |integer a|Size of the object greater than specified for which the corresponding lifecycle rule is to be applied.
|size_less_than |integer a|Size of the object smaller than specified for which the corresponding lifecycle rule is to be applied.
|tags |array[string] a|An array of key-value paired tags of the form or <tag=value>.
[#svm] [.api-collapsible-fifth-title] svm
|name |string a|The name of the SVM. This field cannot be specified in a PATCH method.
|uuid |string a|The unique identifier of the SVM. This field cannot be specified in a PATCH method.
[#s3_bucket_lifecycle_rule] [.api-collapsible-fifth-title] s3_bucket_lifecycle_rule
Information about the lifecycle management rule of a bucket.
|abort_incomplete_multipart_upload |abort_incomplete_multipart_upload a|Specifies a way to perform abort_incomplete_multipart_upload action on filtered objects within a bucket. It cannot be specified with tags.
|enabled |boolean a|Specifies whether or not the associated rule is enabled.
|expiration |expiration a|Specifies a way to perform expiration action on filtered objects within a bucket.
|non_current_version_expiration |non_current_version_expiration a|Specifies a way to perform non_current_version_expiration action on filtered objects within a bucket.
|svm |svm a|Specifies the name of the SVM where this bucket exists.
|uuid |string a|Specifies the unique identifier of the bucket.
[#collection_links] [.api-collapsible-fifth-title] collection_links [#error_arguments] [.api-collapsible-fifth-title] error_arguments
|code |string a|Argument code
|message |string a|Message argument
[#returned_error] [.api-collapsible-fifth-title] returned_error
|arguments |array[error_arguments] a|Message arguments
|code |string a|Error code
|message |string a|Error message
|target |string a|The target parameter that caused the error.
