REST API reference
Update a Snapshot copy policy schedule
Updates a Snapshot copy policy schedule to modify the timing or frequency of Snapshot operations according to your data protection needs.
HTTP method and endpoint
PATCH /storage/snapshot-policies/{snapshot_policy.uuid}/schedules/{schedule.uuid}
Introduced in
ONTAP 9.8
Usage notes
  • snapshot policy modify-schedule
string
path
True
Snapshot copy policy UUID
schedule.uuid
string
path
True
Snapshot copy policy schedule UUID
Request Body
Name Type Description
count
integer
The number of Snapshot copies to maintain for this schedule.
retention_period
string
The retention period of Snapshot copies for this schedule.
schedule
schedule
snapmirror_label
string
Label for SnapMirror operations
snapshot_policy
snapshot_policy
This is a reference to the Snapshot copy policy.
Example request
  "retention_period": "string",
  "schedule": {
    "name": "weekly",
  "snapmirror_label": "string",
  "snapshot_policy": {
    "name": "default",
Status: 200, Ok
Status: Default
ONTAP Error Response Code
Error Code Description
1638451
This operation would result in total Snapshot copy count for the policy to exceed maximum supported count.
918253
Incorrect format for the retention period, duration must be in the ISO-8601 format.
string
schedule
name
string
Job schedule name
uuid
string
Job schedule UUID
snapshot_policy
name
string
uuid
string
snapshot_policy_schedule
The Snapshot copy policy schedule object is associated with a Snapshot copy policy and it defines the interval at which Snapshot copies are created and deleted.
count
integer
retention_period
string
schedule
schedule
snapmirror_label
string
snapshot_policy
snapshot_policy
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
