REST API reference
ONTAP REST API security endpoints
Configure security settings for clusters and SVMs using ONTAP security APIs to safeguard your environment. Implement SAML 2.0 authentication for enhanced security with third-party identity providers.
Overview
You can use ONTAP security APIs to manage security settings for the cluster and SVMs.
SAML
Configure the SAML 2.0 SP (Service Provider) protocol inside ONTAP. Doing so redirects the authentication task to a third-party Identity Provider (IDP) that can utilize any number of approaches for multi-factor authentication. After SAML authentication is enabled, all interactive web access (System Manager, SPI) is authenticated via SAML and a third-party IDP.
