View and update key manager configurations
Access and modify key manager configurations to manage key management settings within your cluster. Use these endpoints to retrieve current configurations or update settings such as polling intervals and retry counts.
Overview
Retrieves or modifies the key management configuration options. The following operations are supported:
GET
PATCH
Retrieving cluster-level key manager configurations
The following example shows how to retrieve cluster-level manager configurations.
# The API:
GET /api/security/key-manager-configs
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/key-manager-configs' -H 'accept: application/hal+json'
# The response:
"cc_mode_enabled": false,
"health_monitor_polling_interval": 15,
"cloud_kms_retry_count": 3,
"href": "/api/security/key-manager-configs"
Updating the cluster-level key manager configurations
The following example shows how to modify the "health_monitor_polling_interval" and "cloud_kms_retry_count" fields.
# The API:
PATCH /api/security/key-manager-configs
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/security/key-manager-configs' -H 'accept: application/hal+json' -d "{ \"health_monitor_polling_interval\" : \"20\", \"cloud_kms_retry_count\" : \"5\" }"
The following example shows how to modify the "cc_mode".
# The API:
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/security/key-manager-configs' -H 'accept: application/hal+json' -d "{ \"cc_mode_enabled\" : \"true\", \"passphrase\": \"current_passphrase\" }"
