REST API reference
View and update MetroCluster interconnects
Use the MetroCluster interconnect endpoints to view and update the status and network settings of interconnects within a MetroCluster configuration. Retrieve detailed information about each interconnect or modify specific network attributes such as address, netmask, and gateway to ensure optimal connectivity.
Overview
You can use this API to retrieve and display relevant information pertaining to MetroCluster interconnect status. The /cluster/metrocluster/interconnects endpoint returns a list of all the interconnects in MetroCluster and their status. Each individual interconnect can be queried individually using the /cluster/metrocluster/interconnects/{node.uuid}/{partner_type}/{adapter} endpoint. You can also use this API to modify relevant information related to MetroCluster interconnect. These include address, netmask, and gateway. Modify a MetroCluster interconnect using the /cluster/metrocluster/interconnects/{node.uuid}/{partner_type}/{adapter} endpoint.
Retrieving MetroCluster interconnects
GET https://<mgmt-ip>/api/cluster/metrocluster/interconnects
  "records": [
          "node": {
              "name": "cluster1_01",
              "uuid": "6fead8fe-8d81-11e9-b5a9-005056826931",
                      "href": "/api/cluster/nodes/6fead8fe-8d81-11e9-b5a9-005056826931"
          "partner_type": "ha",
          "adapter": "e0f",
                  "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/ha/e0f"
          "node": {
          "adapter": "e0g",
                  "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/ha/e0g"
          "node": {
          "partner_type": "dr",
          "adapter": "e0f",
                  "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/dr/e0f"
          "node": {
          "adapter": "e0g",
                  "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/dr/e0g"
          "node": {
          "partner_type": "aux",
          "adapter": "e0f",
                  "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/aux/e0f"
          "node": {
          "adapter": "e0g",
                  "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/aux/e0g"
          "node": {
              "name": "cluster1_02",
              "uuid": "f5435191-8d81-11e9-9d4b-00505682dc8b",
                      "href": "/api/cluster/nodes/f5435191-8d81-11e9-9d4b-00505682dc8b"
          "adapter": "e0f",
                  "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/ha/e0f"
          "node": {
          "adapter": "e0g",
                  "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/ha/e0g"
          "node": {
          "adapter": "e0f",
                  "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/dr/e0f"
          "node": {
          "adapter": "e0g",
                  "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/dr/e0g"
          "node": {
          "adapter": "e0f",
                  "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/aux/e0f"
          "node": {
          "adapter": "e0g",
                  "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/aux/e0g"
  "num_records": 12,
          "href": "/api/cluster/metrocluster/interconnects"
Retrieves information about a specific MetroCluster interconnect
https://<mgmt-ip>/api/cluster/metrocluster/interconnects/774b4fbc-86f9-11e9-9051-005056825c71/aux/e0f
  "node": {
      "uuid": "46147363-9857-11e9-9a55-005056828eb9",
              "href": "/api/cluster/nodes/46147363-9857-11e9-9a55-005056828eb9"
  "adapter": "e0f",
  "state": "up",
  "type": "iwarp",
  "interfaces": [
      "address": "10.2.3.5",
      "netmask": "255.255.255.0"
  "mirror": {
      "state": "online",
      "enabled": true
  "multipath_policy": "static_map",
          "href": "/api/cluster/metrocluster/interconnects/46147363-9857-11e9-9a55-005056828eb9/ha/e0f"
This example shows how to modify the network address assigned to the home port. Fields required: address.
curl -X PATCH https://<mgmt-ip>/api/cluster/metrocluster/interconnects/3e1bfd38-ffd2-11eb-bcb7-005056aceaa9/ha/e0g -d '{"interfaces": [{"address": "1.2.3.4"}]}'
PATCH Response
HTTP/1.1 200 OK
Cache-Control: no-cache,no-store,must-revalidate
Connection: close
Date: Fri, 20 Aug 2021 21:58:36 GMT
Server: libzapid-httpd
Content-Length: 3
Content-Type: application/hal+json
X-Content-Type-Options: nosniff
This example shows how to modify the netmask assigned to the interface. Be sure to change to a valid subnet. Fields required: netmask.
curl -X PATCH https://<mgmt-ip>/api/cluster/metrocluster/interconnects/3e1bfd38-ffd2-11eb-bcb7-005056aceaa9/ha/e0g -d '{"interfaces": [{"netmask": "2.2.2.2"}]}'
PATCH Response
HTTP/1.1 200 OK
Connection: close
Date: Fri, 20 Aug 2021 22:11:35 GMT
Content-Length: 3
This example shows how to modify the gateway assigned to the interface. Please make sure to update it on the switch/router first. Assuming it is a new one, the new gateway and IP address must reside in the same subnet range as the interface IP address. Fields required: gateway.
curl -X PATCH https://<mgmt-ip>/api/cluster/metrocluster/interconnects/3e1bfd38-ffd2-11eb-bcb7-005056aceaa9/ha/e0g -d '{"interfaces": [{"gateway": "1.2.3.4"}]}'
PATCH Response
HTTP/1.1 200 OK
Connection: close
Content-Length: 3
