View and update OAuth 2.0 status
Use this API to manage the OAuth 2.0 status in your cluster. Enable or disable OAuth 2.0 to control authentication settings effectively.
Overview
This API is used to enable and disable OAuth 2.0 in the cluster. The PATCH request enables and disables OAuth 2.0 in the cluster.
Retrieving the OAuth 2.0 status in the cluster
The following output shows the OAuth 2.0 status of the cluster.
# The API:
/api/security/authentication/cluster/oauth2
# The call:
curl -X GET "https://<mgmt-ip>/api/security/authentication/cluster/oauth2" -H "accept: application/hal+json"
# The response:
"enabled": false
Enabling the OAuth 2.0 in the cluster
The following output shows how to enable the OAuth 2.0 in the cluster.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/authentication/cluster/oauth2" -H "accept: application/hal+json" -d '{ "enabled": true }'
