Cluster NTP servers endpoint overview
Overview
You can use this API to add external NTP servers to a cluster, update the configuration, use NTP keys, and retrieve the current NTP server configuration.
Adding an NTP server to a cluster
To add an NTP server to a cluster, issue a POST /cluster/ntp/servers request.
Fields used for adding an NTP server
Except for the name of the NTP server (host name or IP address), which is specified by the server, all fields are optional:
version -
key
If the key is provided in POST, authentication_enabled is set to true by default.
# Body
add_ntp_server.txt(body):
"server": "time.nist.gov"
# Request
curl -X POST "https://<mgmt-ip>/api/cluster/ntp/servers" -d "@add_ntp_server.txt"
Adding an NTP server with an authentication key
# Body
add_authenticated_ntp_server.txt(body):
"server": "time.nist.gov",
"key": { "id": 10 }
# Request
curl -X POST "https://<mgmt-ip>/api/cluster/ntp/servers" -d "@add_authenticated_ntp_server.txt"
Enabling a previously configured shared key (ID, type, and value) for an NTP server
A combination of key number or identifier (ID), type of key, and shared key value is created with /api/cluster/ntp/keys. This operation will validate the NTP authentication works.
# Body
enable_shared_key.txt(body):
"key": { "id": 10 },
"authentication_enabled": true
# Request
curl -X PATCH "https://<mgmt-ip>/api/cluster/ntp/servers/time.nist.gov" -d "@enable_shared_key.txt"
