Remove a reporting node and its HA partner from a LUN map
Removes a reporting node and its HA partner from a LUN map, modifying the configuration to update the association with the specified nodes.
HTTP method and endpoint
DELETE /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}/reporting-nodes/{uuid}
Introduced in
ONTAP 9.10
Related ONTAP commands
lun mapping remove-reporting-nodes
lun.uuid |
string |
path |
True |
igroup.uuid |
string |
path |
True |
uuid |
string |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374608 |
An attempt was made to delete the last reporting node for a LUN. The REST API requires that a LUN map must maintain at least one reporting node. |
5374875 |
The specified LUN does not exist or is not accessible to the caller. |
5374878 |
The specified initiator group does not exist, is not accessible to the caller, or is not in the same SVM as the specified LUN. |
5374922 |
The specified LUN map does not exist. |
5376454 |
Modifying reporting nodes of a LUN map is not supported on this platform. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
